16642 Discussions
I/O assignment analysis fail Quartus Prime Lite 23.1 for CycloneV
minhlee
Hi everyone, currently I am creating my own SoC system. I have run Analysis and Synthesis successfully, then I run tcl script hps_sdram_p0_parameters.tcl and hps_sdram_p0_pin_assignments.tcl respectively.  After that, I run I/O assignment analysis and receive this error:
Critical Warning (169085): No exact pin location assignment(s) for 120 pins of 172 total pins. For the list of pins please refer to the I/O Assignment Warnings table in the fitter report.
Critical Warning (174073): No exact pin location assignment(s) for 1 RUP, RDN, or RZQ pins of 1 total RUP, RDN or RZQ pins
	Info (174074): RUP, RDN, or RZQ pin HPS_DDR3_RZQ not assigned to an exact location on the device
Info (184020): Starting Fitter periphery placement operations
Error (14996): The Fitter failed to find a legal placement for all periphery components
	Error (14986): After placing as many components as possible, the following errors remain:
		Error (175001): The Fitter cannot place 30 pins.
			Info (14596): Information about the failing component(s):
				Info (175028): The pin name(s): HPS_DDR3_DQ[8], HPS_DDR3_DQ[9], HPS_DDR3_DQ[10], HPS_DDR3_DQ[11], HPS_DDR3_DQ[12] and other 25 pins
				Info (15647): These pins are in a group of 30 components with similar legality requirements
			Error (16234): No legal location could be found out of 176 considered location(s).  Reasons why each location could not be used are summarized below:
				Error (184016): There were not enough single-ended bidirectional pin locations available (91 locations affected)
					Info (175029): Y9. Already placed at this location: pin altera_reserved_tdo
						Info (175015): The I/O pad altera_reserved_tdo is constrained to the location PIN_Y9 due to: JTAG placement
							Info (14709): The constrained I/O pad is contained within this pin
					Info (175029): AC7. Already placed at this location: pin altera_reserved_tms
						Info (175015): The I/O pad altera_reserved_tms is constrained to the location PIN_AC7 due to: JTAG placement
					Info (175029): AB5. Already placed at this location: pin altera_reserved_tck
						Info (175015): The I/O pad altera_reserved_tck is constrained to the location PIN_AB5 due to: JTAG placement
					Info (175029): W10. Already placed at this location: pin altera_reserved_tdi
						Info (175015): The I/O pad altera_reserved_tdi is constrained to the location PIN_W10 due to: JTAG placement
					Info (175029): Y8. Already placed at this location: pin HDMI_TX_D[3]
						Info (175015): The I/O pad HDMI_TX_D[3] is constrained to the location PIN_Y8 due to: User Location Constraints (PIN_Y8)
					Info (175029): Y4. Already placed at this location: pin HDMI_TX_D[9]
						Info (175015): The I/O pad HDMI_TX_D[9] is constrained to the location PIN_Y4 due to: User Location Constraints (PIN_Y4)
					Info (175029): W8. Already placed at this location: pin HDMI_TX_D[2]
						Info (175015): The I/O pad HDMI_TX_D[2] is constrained to the location PIN_W8 due to: User Location Constraints (PIN_W8)
					Info (175029): Y5. Already placed at this location: pin HDMI_TX_D[7]
						Info (175015): The I/O pad HDMI_TX_D[7] is constrained to the location PIN_Y5 due to: User Location Constraints (PIN_Y5)
					Info (175029): T8. Already placed at this location: pin HDMI_TX_HS
						Info (175015): The I/O pad HDMI_TX_HS is constrained to the location PIN_T8 due to: User Location Constraints (PIN_T8)
					Info (175029): AB4. Already placed at this location: pin HDMI_TX_D[11]
						Info (175015): The I/O pad HDMI_TX_D[11] is constrained to the location PIN_AB4 due to: User Location Constraints (PIN_AB4)
					Info (175029): AA4. Already placed at this location: pin HDMI_I2C_SDA
						Info (175015): The I/O pad HDMI_I2C_SDA is constrained to the location PIN_AA4 due to: User Location Constraints (PIN_AA4)
					Info (175029): U10. Already placed at this location: pin HDMI_I2C_SCL
						Info (175015): The I/O pad HDMI_I2C_SCL is constrained to the location PIN_U10 due to: User Location Constraints (PIN_U10)
					Info (175029): and 79 more locations not displayed
				Error (179008): Could not find enough available I/O pin locations that can be configured to use a VCCIO voltage of 2.5V (85 locations affected)
					Info (175029): U9
					Info (175029): V10
					Info (175029): AD4
					Info (175029): AC4
					Info (175029): AA11
					Info (175029): AE6
					Info (175029): Y11
					Info (175029): AD5
					Info (175029): AF4
					Info (175029): W11
					Info (175029): AF7
					Info (175029): AH3
					Info (175029): and 73 more locations not displayed
Info (184021): Fitter periphery placement operations ending: elapsed time is 00:00:01
Info (11798): Fitter preparation operations ending: elapsed time is 00:00:18
Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
Warning (169064): Following 60 pins have no output enable or a GND or VCC output enable - later changes to this connectivity may change fitting results
	Info (169065): Pin HDMI_I2S has a permanently disabled output enable
	Info (169065): Pin HDMI_LRCLK has a permanently disabled output enable
	Info (169065): Pin HDMI_MCLK has a permanently disabled output enable
	Info (169065): Pin HDMI_SCLK has a permanently disabled output enable
	Info (169065): Pin HPS_CONV_USB_N has a permanently disabled output enable
	Info (169065): Pin HPS_ENET_INT_N has a permanently disabled output enable
	Info (169065): Pin HPS_ENET_MDIO has a permanently disabled output enable
	Info (169065): Pin HPS_GSENSOR_INT has a permanently disabled output enable
	Info (169065): Pin HPS_I2C0_SCLK has a permanently disabled output enable
	Info (169065): Pin HPS_I2C0_SDAT has a permanently disabled output enable
	Info (169065): Pin HPS_I2C1_SCLK has a permanently disabled output enable
	Info (169065): Pin HPS_I2C1_SDAT has a permanently disabled output enable
	Info (169065): Pin HPS_KEY has a permanently disabled output enable
	Info (169065): Pin HPS_LED has a permanently disabled output enable
	Info (169065): Pin HPS_LTC_GPIO has a permanently disabled output enable
	Info (169065): Pin HPS_SD_CMD has a permanently disabled output enable
	Info (169065): Pin HPS_SD_DATA[0] has a permanently disabled output enable
	Info (169065): Pin HPS_SD_DATA[1] has a permanently disabled output enable
	Info (169065): Pin HPS_SD_DATA[2] has a permanently disabled output enable
	Info (169065): Pin HPS_SD_DATA[3] has a permanently disabled output enable
	Info (169065): Pin HPS_SPIM_SS has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[0] has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[1] has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[2] has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[3] has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[4] has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[5] has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[6] has a permanently disabled output enable
	Info (169065): Pin HPS_USB_DATA[7] has a permanently disabled output enable
	Info (169065): Pin HDMI_I2C_SCL has a permanently enabled output enable
	Info (169065): Pin HPS_DDR3_DQ[8] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[9] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[10] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[11] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[12] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[13] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[14] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[15] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[16] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[17] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[18] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[19] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[20] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[21] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[22] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[23] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[24] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[25] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[26] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[27] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[28] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[29] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[30] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQ[31] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQS_N[1] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQS_N[2] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQS_N[3] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQS_P[1] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQS_P[2] has a permanently disabled output enable
	Info (169065): Pin HPS_DDR3_DQS_P[3] has a permanently disabled output enable
Warning (169069): Following 72 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results
	Info (169070): Pin HPS_DDR3_ADDR[13] has GND driving its datain port
	Info (169070): Pin HPS_DDR3_ADDR[14] has GND driving its datain port
	Info (169070): Pin HPS_DDR3_DM[1] has GND driving its datain port
	Info (169070): Pin HPS_DDR3_DM[2] has GND driving its datain port
	Info (169070): Pin HPS_DDR3_DM[3] has GND driving its datain port
	Info (169070): Pin HPS_ENET_GTX_CLK has GND driving its datain port
	Info (169070): Pin HPS_ENET_MDC has GND driving its datain port
	Info (169070): Pin HPS_ENET_TX_DATA[0] has GND driving its datain port
	Info (169070): Pin HPS_ENET_TX_DATA[1] has GND driving its datain port
	Info (169070): Pin HPS_ENET_TX_DATA[2] has GND driving its datain port
	Info (169070): Pin HPS_ENET_TX_DATA[3] has GND driving its datain port
	Info (169070): Pin HPS_ENET_TX_EN has GND driving its datain port
	Info (169070): Pin HPS_SD_CLK has GND driving its datain port
	Info (169070): Pin HPS_SPIM_CLK has GND driving its datain port
	Info (169070): Pin HPS_SPIM_MOSI has GND driving its datain port
	Info (169070): Pin HPS_UART_TX has GND driving its datain port
	Info (169070): Pin HPS_USB_STP has GND driving its datain port
	Info (169070): Pin HPS_CONV_USB_N has VCC driving its datain port
	Info (169070): Pin HPS_ENET_INT_N has VCC driving its datain port
	Info (169070): Pin HPS_ENET_MDIO has VCC driving its datain port
	Info (169070): Pin HPS_GSENSOR_INT has VCC driving its datain port
	Info (169070): Pin HPS_I2C0_SCLK has VCC driving its datain port
	Info (169070): Pin HPS_I2C0_SDAT has VCC driving its datain port
	Info (169070): Pin HPS_I2C1_SCLK has VCC driving its datain port
	Info (169070): Pin HPS_I2C1_SDAT has VCC driving its datain port
	Info (169070): Pin HPS_KEY has VCC driving its datain port
	Info (169070): Pin HPS_LED has VCC driving its datain port
	Info (169070): Pin HPS_LTC_GPIO has VCC driving its datain port
	Info (169070): Pin HPS_SD_CMD has VCC driving its datain port
	Info (169070): Pin HPS_SD_DATA[0] has VCC driving its datain port
	Info (169070): Pin HPS_SD_DATA[1] has VCC driving its datain port
	Info (169070): Pin HPS_SD_DATA[2] has VCC driving its datain port
	Info (169070): Pin HPS_SD_DATA[3] has VCC driving its datain port
	Info (169070): Pin HPS_SPIM_SS has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[0] has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[1] has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[2] has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[3] has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[4] has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[5] has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[6] has VCC driving its datain port
	Info (169070): Pin HPS_USB_DATA[7] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[8] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[9] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[10] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[11] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[12] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[13] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[14] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[15] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[16] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[17] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[18] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[19] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[20] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[21] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[22] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[23] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[24] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[25] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[26] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[27] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[28] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[29] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[30] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQ[31] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQS_N[1] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQS_N[2] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQS_N[3] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQS_P[1] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQS_P[2] has VCC driving its datain port
	Info (169070): Pin HPS_DDR3_DQS_P[3] has VCC driving its datain port
Info (169186): Following groups of pins have the same dynamic on-chip termination control
	Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[0] uses the SSTL-15 Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[1] uses the SSTL-15 Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[2] uses the SSTL-15 Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[3] uses the SSTL-15 Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[4] uses the SSTL-15 Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[5] uses the SSTL-15 Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[6] uses the SSTL-15 Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQ[7] uses the SSTL-15 Class I I/O standard
	Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|diff_dtc_bar
		Info (169066): Type bi-directional pin HPS_DDR3_DQS_N[0] uses the Differential 1.5-V SSTL Class I I/O standard
		Info (169066): Type bi-directional pin HPS_DDR3_DQS_P[0] uses the Differential 1.5-V SSTL Class I I/O standard
Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 7 errors, 26 warnings
	Error: Peak virtual memory: 5552 megabytes
	Error: Processing ended: Sat Apr 27 03:20:34 2024
	Error: Elapsed time: 00:00:45
	Error: Total CPU time (on all processors): 00:00:37
What can I do to solve this problem?
ShengN_Intel
The error due to the width mismatch between the ports of top module DE10_NANO_SoC_GHRD.v and the ports of msdma_fpga.
Modify the lines below in DE10_NANO_SoC_GHRD.v then there'll be no error anymore after running the tcl script and I/O assignment analysis:
Line 29: output  [/*14*/12: 0]  HPS_DDR3_ADDR,
Line 37: inout  [/*31*/7: 0]  HPS_DDR3_DQ,
Line 39: inout  /*[ 3: 0]*/  HPS_DDR3_DQS_P,
Sheng
sstrell
It looks like you may have made manual pin assignments to pins dedicated to the HPS, like those HDMI signals as well as assignments to the dedicated JTAG pins.  What does your Pin Planner look like?
minhlee
Hi @strell, here is my zip file contain my project.  Basically, I am currently learning how to use mSGDMA core from this tutorial: https://blog.reds.ch/?p=835 to access DRAM from FPGA in my de10 nano.
Kenny_Tan
We will need sometime to look into the design. stay tune
ShengN_Intel
Sheng
minhlee
