16666 Discussions
Max V 5M80ZE64C5N examine / Verify Failure still unsolved
TN-Notebooks
Hallo
the Issue is still unsolved but in the Thread i get no answer a log time ......
https://community.intel.com/t5/Programmable-Devices/Max-V-5M80ZE64C5N-examine-Verify-Failure/m-p/1543982/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExPWjNWMVM2Q1BENUtEfDE1NDM5ODJ8U1VCU0NSSVBUSU9OU3xoSw#M93492
Synology Board with 5M80ZE64C5N
PL-USB Blaster RCN  Rev C
Software
Win 10
Device selected 5M80ZE64
selectable  Boxes ( dark grey ) : Blank check - examine - erase
not selectable  Boxes ( light grey ) : Programm - verify - security Bit - ISP Clamp
( exactly same on Brand new chip  )
Examine successful 100%
File saved
USM and CFM appear
Verify USM pass
Verify  CFM Fail
Message  :
209048 verfy failure on devive number 1
209012 Operation failed
to check the behavior i bought a brand new DK-DEV-5M570ZN Development Kit
connection all fine.
Erase performed success
Blank Check  success
now examine the erased blank Chip  - save the File and now verify  of the examined erased/blank chip
........ Failed
So this is not a Hardware or Security Bit Problem  -- seem to be a Bug in Quartus
Fakhrul
Hi TN-Notebooks,
Based on the previous thread you mentioned, I believe you only wanted to examine the board for the cloning purpose, correct?
If you have no issue with examine, may I now the reason you would like to verify it?
Fakhrul
TN-Notebooks
Hallo
"Based on the previous thread you mentioned, I believe you only wanted to examine the board for the cloning purpose, correct?"
--> Yes this is correct
"If you have no issue with examine, may I now the reason you would like to verify it?"
--> This is wrong.
The examined Files are not working - they are empty.  Examine is not working.
If i install on a Clone the examined File  its not working.
So finally verify confirms correctly that the examine File do not agree with the Source Chip.
Seem that Examine is Faulty by Quartus Software
This Faulty Examine behavior is confirmed with my Boards and a original Development Board.
Fakhrul
Hi TN-Notebooks,
I'm still checking on the root cause of this. Meanwhile, can you try to use the latest version of Quartus lite? let's see the result;
Intel® Quartus® Prime Lite Edition Design Software Version 23.1
Fakhrul
TN-Notebooks
Hallo
i installed the latest Quartus lite 23.1
same Behavior - same Fault
UFM examine and Verify ok
CFM examine and Verify fail
File attached
TN-Notebooks
Fakhrul
Hi TN-Notebooks,
I am currently searching internally for the required details to address this matter. My apologies for the delay. I will provide you with an update as soon as we acquire the necessary information.
Fakhrul
Fakhrul
Hi TN-Notebooks,
Sorry for the delay. Upon checking, it appears that this issue has been resolved starting from Quartus 23.1 standard version?
Could you try with 23.1 standard version this time?
Fakhrul
TN-Notebooks
I have no lizenz for the 23.1 standard version
But
The stand alone Programmer of the Standard Version i already tried and the Failure is NOT solved .
Fakhrul
Hi TN-Notebooks,
Could you try the following step:
1. Uninstall the current usb blaster driver, then try to update the driver to the higher version, such as usb blaster driver for 17.1 or later version.
2. If it is impossible to update the usb blaster driver ,we recommend you to modify the JTAG circuit on your board, and adjust the pull-up resistor of TCK TMS to modify jtag timing.
Fakhrul
*Please be informed that we will be out of office from 8/April to 12/April due to a public holiday here. Kindly expect some delay in response if you are going to post an update.
TN-Notebooks
Hallo,
i never had or used a version older than 17.1
so fur sure its a usb blaster driver for 17.1 or later version .
Prior last Test i deinstalled ALL Software and installed everything from  the latest Quartus lite 23.1
Thomas
Fakhrul
Hi TN-Notebooks,
Upon checking, I found out that the lates supported Quartus software for MAX V is 21.1 both for the standard and lite versions. You may check it here: Intel® Quartus® Software Latest Version for Device Support
Please try with the latest supported Quartus version (21.1) and let me know the outcome.
Fakhrul
TN-Notebooks
Hallo,
the Versions 18.x  up to Version 22.x  (21.1 included )  is not useable because it have a other Bug
If you Examine you can not save the File and the Software closes by itself .
see
https://community.intel.com/t5/Intel-Quartus-Prime-Software/saving-the-examined-data-of-Max-V-failed-in-the-Intel-Quartus/m-p/1528737#M80146
This Bug is solved in the Version 23
But the Standalone Programmer should support the MAX V also in Version 23.x  ??
Farabi
We have discussed with engineering on this, and several tests has been performed on MAXV devkit to examine the contents.
We don't observed any error and able to download the image from the device successfully.
Is it something related to your design specifically? Moving forward, we need help from you to provide below items:
  1. Can you share the design so we can replicate the issue on our setup?
  2. How many devices you observed failing to examine? eg. 2 out of 10
regards,
Farabi
TN-Notebooks
Hallo
Blank Check  success
........  ok for UFM  but Failed for CFM
 i tried also on several different Synology NAS Systems.
affected 10 of 10  ---- ALL
as Programmer  i use   PL-USB-BLTR-RCN   on Cable  2006 Altera P06-18025R-00 RoHS
Fakhrul
Hi TN-Notebooks,
We are checking with the internal team and will update to you within this week.
Fakhrul
Farabi
This need to be escalated to engineering to make sure they provide the fix.
regards,
Farabi
TN-Notebooks
Hallo
additional  Info
for further investigation i bought a
PL-USB2-Blaster       original Altera
Same Failure  also with this Programmer.
Problem NOT solved
Fakhrul
Hi TN-Notebooks,
I have sent you an email to get in touch and provide updates, as we have escalated this issue to our Engineering Team. Consequently, this thread will be transitioned to community support.
Fakhrul
