16642 Discussions
Questasim*-Intel FPGA Starter Edition floating license issue.
MGRazor
We are still experiencing Questasim*-Intel FPGA Starter Edition floating license issue. Tried fixed license as well with no luck. We need help.
AR_A_Intel
New license.
AR_A_Intel
Welcome to the INTEL forum. Could you assist in setting up the new license.dat file attached? Let's see how things progress.
MGRazor
Thank you for replying.
Issue persist with Questa with new license provided. Quartus runs fine but once I try running Gate Level Simulation I get Fatal error.
AR_A_Intel
Hi
To narrow down this issue, can you please provide me the latest of the following?
1) Debug/error .log file
2) assembler report .asm.rpt file
3) Machine OS information
MGRazor
Aside the machine OS info where can I find the *log and *.asm.rpt files??
AR_A_Intel
Hi
You can refer to this following YouTube on how to find debug log file ( min.2:55)
https://www.youtube.com/watch?v=llLaWatUbe8
And the asm.rpt.
The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
You can also reply/attach your file in private message.
MGRazor
Thank you.
Please refer to the attachments.
AR_A_Intel
Hi
May we know, Is it Questa Intel FPGA starter edition or non-starter edition?
What is report out when run this cmd “ lmutil.exe lmdiag intelqsim “ in the command prompt?
Could you also provide, Output of “lmutil lmstat –a –c <port>@<address>” server and client
MGRazor
Results from two clients and server
MGRazor
Results from two clients rather.
AR_A_Intel
Could you help upgrade the license vendor daemon software to the newer version here and try it again. TQ
https://www.intel.com/content/www/us/en/software-kit/709649/license-daemon.html
MGRazor
I suppose the choice is:
Flexlm License Daemon v11.16.4.0 for Siemens ModelSim/Questa Intel FPGA software (64-bit OS)
I upgrade please see attachment.
MGRazor
Here is from client.
Still fails.
MGRazor
See debug.log file attached after Deamon upgrade and client result.
AR_A_Intel
Hi
Could you provide your latest lmutil lmstat –a –c <port>@<address>” server and client for checking. TQ
MGRazor
Here you go.
Please refer to attachments.
AR_A_Intel
Hi
Thanks for update. Please give me some time to further check. I’ll be back with further information.
AR_A_Intel
Hi
Thanks for your patience. Could you please restart your machine and server from scratch? Upon checking, It seems that a server reboot is necessary for the changes to take effect.
