Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Can't install win 7 on X25 Gen. 2
Hi. I have an problem with installing Win 7 on my X25 Gen. 2 ssd drive 80 gigabyte version. I formatted the disk under installation of win 7, when I come to the alternative where I want to install, it says installation program can't create a new system partition or find an existing system partition, look at the log files for installation for more information. I have also tried to format the disk with Gparted. Can someone Help meg to find an solution?
RGiff
Honored Contributor I
Did you make sure it's formated NFTS and not FAT32
Community Manager
Would you happen to have a USB drive plugged into the computer? I have had this happen before as well due to that... it's weird.
Community Manager
Had the same problem, I had to disconnect all drives and just do the install with just the SSD connected (Intel 510 120gb).
The install worked fine after that, I connected the drives after shutting down and windows discovered them on boot up.
