Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Dell 7490 does not see SSD 660p in the bios
kolmen
Dell 7490 does not see ssdpeknw010t8 in the BIOS
Bios is updated
What should i do ?
LeonWaksman
Intel SSD 660p is an NVMe SSD. You should have UEFI boot enabled.
Leon
kolmen
Uefi boot is enabled. The Samsung NVMe drive is detected correctly with the same settings
n_scott_pearson
Super User Retired Employee
The 660p may have failed. Have you been using this drive for some time or is it new? If it is new, I would be returning it to the place of purchase and getting a replacement.
LeonWaksman
Hi @kolmen
I can't see if you have the latest BIOS Version 1.16.0, 1.16.0 installed. If not, please update your BIOS.
Leon
kolmen
Bios was upgraded
JosafathB_Intel
Hello, kolmen,
Thank you for contacting Intel® Memory and Storage support.
As we understand, you need assistance with your Intel® SSD 660p Series that is not detected by your Dell* PC. We would appreciate it if you provide us with the following information:
1-  Is this drive new, or it came preinstalled with your PC?
2- Do you have access to another PC that you can use to test this SSD?
3- We would appreciate it if you can provide us with pictures of the SSD labels to check the information it contains. The SSD’s serial number and part number need to legible.
-We advise you to open a ticket in parallel with DELL* to confirm that the compatibility of your current configuration with the SSD.
We are going to follow up with you again next Thursday, the 3rd of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
Josh B.
Intel® Customer Support Technician.
kolmen
Hello, Josh
1. new
2. i tested this SSD today in Acer PC and works fine
3. picture is in attachement
JosafathB_Intel
Hello, kolmen,
Thank you for your reply.
Based on the information you shared with us, the SSD is working without any issues in your Acer* PC. Based on this, we can conclude that the not detection issue is related to the Dell* PC and not to the SSD itself.
We recommend you to work with the OEM Dell* to see if there is a compatibility issue between the system and the SSD or if any specific BIOS configuration is needed.
We are going to follow up with you again next Tuesday, the 8th of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
We will be looking forward to your reply in case you need further assistance.
Josh B.
JosafathB_Intel
Hello, kolmen,
Greetings from; Intel® Memory and Storage support.
We were reviewing your community thread, which is related to the Intel® SSD 660p Series. We would like to know if you were able to contact the PC OEM to check compatibility.
We are going to follow up with you again next Friday, the 11th of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
Josh B.
JosafathB_Intel
Hello, kolmen,
We were reviewing your community thread, which is related to the Intel® SSD 660p Series, and we have not heard back from you in a while, so we will proceed to close this inquiry now.
If you need assistance with an Intel® product, please open a new thread.
Josh B.
