Community
cancel
Showing results for
Search instead for
Did you mean:
amash1
How to configure the Intel P3608 PCIe SSD IN RAID? X99+Win8.1
Hello
i need help with my P3608 1.6TB RAID 0 setup.
so i have Asrock X99 WS-E
OS SSD M.2 is Samsung 250GB.
Win 8.1 / 10 - X64 Tried Both.
after Installing the latest drivers NVMe and the RSTe software
When entering the RSTe GUI software all i can see is my M.2 SSD
cant see my P3608 in wich i want to make a Raid 0 volume
ASouz7
Alopa,
Raid 0 works better if the SSDs are identical (same size and same write and read speeds) and if possible, start it with the drives blank/formatted. Raid controllers use SATA and SAS drives in most cases. You might want to consult the Forums for more information on Intel® Rapid Storage Technology.
ASouz7
Alopa,
We are still investigating the RST with NVMe* on Intel® X99 Chipset. Please gives some time to check this for you.
amash1
i cant get it to work with Gigabyte Z170-HD3 either.
with new skyplake processors
In the RTSe GUI Utility i cant see the nvme chipset.
only sata controler with sata SSD
i see both disks in the device manager and the intel Solid-State Drive Toolbox
