Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel Warranty Coverage Check
Community Manager
I have an issue doing a warranty check on an intel ssd 535 series which died. I keep getting "your product could not be located" on different browsers. See attached jpg. This seems to be limited to the 535 series, as I have checked serial numbers for 525, 530, 540 and 600P series ssd and have no issues. I have checked two different serial numbers for the 535 series and both get errors.
Community Manager
Hello kgreenh,
In some cases the Warranty Information tool may have a hard time locating your product, this issue has been reported and should be resolved in the near future.
For products experiencing this problem, we suggest checking your warranty status using the "Other Intel® Product" option. Here you will need to input both your ISN and your SA numbers:
If this still does not display your estimated warranty expiration date, you will need to http://www.intel.com/content/www/us/en/support/contact-support.html contact our support team directly for assistance.
Carlos A.
