Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Issue with SSD Toolbox
Hi, i just installed 80GB 25-M ssd - OS - XPSP3 PC - dell e6400
When i open the drive toolbox I do not see any drives listed...i downloaded the latest toolbox, latest rapid store tech and latest bios for my laptop...
any ideas on whats going on?
vt5
try reinstalling the SSD toolbox program, lastly, you can check your drive configuration settings in the laptop BIOS, try tweaking from AHCI to IDE, vice versa
Community Manager
removed and reinstalled the toolbox several times with no luck..
tried using different settings in the bios..and as expected the os didnt boot....not at the point yet where i feel like doing a reinstall of the os.
.net 2.0, 3.0, 3.5 and 4 are all in my add/remove programs list....along with various service packs.
Community Manager
In order to boot in AHCI mode after an OS install, you must perform a simple registry change described here:
http://windows7themes.net/switch-to-ahci-after-install-windows-7.html http://windows7themes.net/switch-to-ahci-after-install-windows-7.html
I've done this myself on several PCs and it works just fine.
Community Manager
running XP if that matter...and im already in AHCI mode via the bios and XP drivers...are you saying i can go backwards via registry, reboot (w/bios changes) and it should work?
Community Manager
okay..so i tried the toolbox on another machine (same machine hardware, with XP as well) and it works fine...so there is something up with this particular machine and the XP configuration?!?!
any ideas would be helpful...i checked for the .NET installs, checked bios settings, and both are same between the two laptops.
Community Manager
When you installed the Toolbox, did you notice that it also installed .NET Framework 2.0, which is required for the Toolbox? Check your installed programs from the Control Panel if you aren't sure.
