Community
cancel
Showing results for
Search instead for
Did you mean:
AWong15
Unlock PC Opal Encryption
Hello all,
I have a Intel M.2 SSD which was locked by McAfee PC Opal Encryption. However, it was not usable after remove the McAfee Encryption using EETech. No way to format the drive or delete the partition under window 10 or apple environments. Any idea how to recover the driver? If possible, I would like to try keeping all data in the SSD. Please help.
Community Manager
Hi anson1999,
Thank you for posting in the Intel communities.
If I understood you well, your drive was locked by McAfee PC Opal Encryption and you are not able to access the data in it, correct?
Could you please explain how you got the drive locked by the McAfee application?
Additionally, which drive do you have exactly? If you cannot see the drive in the system, please take a screenshot of the label on the SSD. The information in the label will help us to identify the drive.
I'll be waiting for your response.
Have a nice day.
Diego V.
AWong15
Hello Diego,
Yes, you are correct, it was locked by McAfee PC Opal Encryption, and now the drive does not able to read, write, format and delete the partition. I also tried to use Intel SSD Pro Administrator Tool v2.0.2 to force delete the date. However, it does not successful. The McAfee PC Opal encryption was installed by McAfee policy via McAfee EPO server. The SSD model is SSDSCKKF180H6L which is M.2 drive. Attached picture for the reference. Thanks.
Community Manager
Hi anson1999,
Thank you for the information.
Please let me investigate about this to see if there is a way to format the drive even though it has been locked.
On the other hand, this doesn't look like an issue with the drive itself, but with the McAfee application locking the drive. Have you tried to contact McAfee to explain them the issue and see if they have a fix or suggested solution to unlock or format the drive? If not, I'd recommend you to do so as they may have alternative approaches for these scenarios. Actually, they have a community where you can post your concern: https://community.mcafee.com/ https://community.mcafee.com/
I'll investigate from my side and post any updates I'm able to find as soon as possible.
Have a nice day.
Diego V.
AWong15
Hello Diego,
Thank you for your update. I did contacted McAfee support, but according to their information, the drive is already unlocked because the drive encryption already removed, but somehow the SSD cannot release the lock. Please kindly help to see anyway to release the lock or reset the drive. I will also post the issue to McAfee community. Hope someone know how to fix the issue there. Thanks.
Community Manager
Hi anson1999,
I was able to find a way that should work to reset an Opal locked drive using the Intel® SSD Pro Admin Tool. I'm not sure if you have tried this as you mentioned that you already used this tool.
You should use the PSID that is on the drive label to perform an Opal Revert. This process will return the drive back to factory settings which means the data will be lost.
Please try this method. You can find a well explanation about this in the following user guide for the tool (page 11): https://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/ssd-software/Intel_SSD_... https://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/ssd-software/Intel_SSD_...
Make sure the drive is connected directly to the motherboard in the correct slot. If you have the drive connected through USB using some kind of adapter, the process won't work.
You can download the Intel® SSD Pro Admin Tool from this site in case you don't have the latest version: https://downloadcenter.intel.com/download/27496/Intel-SSD-Pro-Administrator-Tool https://downloadcenter.intel.com/download/27496/Intel-SSD-Pro-Administrator-Tool
I hope this process helps you.
Have a nice day.
Diego V.
AWong15
Hello Diego,
I tried but it gave me error. The drive is attached to computer directly and under WinPE environment. Please see below. Thanks.
SSDProAdminTool_2.0.2.401_win32.exe show
- Intel SSD Pro 5400s Series Opal Ready CVLY63030265180C -
Model Number INTEL SSDSCKKF180H6L
Device Path .PHYSICALDRIVE0
Marketing String Intel SSD Pro 5400s Series Opal Ready
Firmware LSFL37P
Serial Number CVLY63030265180C
Index 0
Device Status Healthy
Opal State Opal Activated
eDrive Supported False
SSDProAdminTool_2.0.2.401_win32.exe psid_revert -intelssd 0
The PSID revert operation will revert the drive back to its original factory state.
THIS OPERATION WILL MAKE ALL THE DATA ON YOUR DRIVE INACCESSIBLE!
Intel is not responsible for loss of data using this tool.
WARNING! PSID revert will erase ALL the data on the drive!
Proceed with the operation (YN) Y
Enter SSD Pro Series PSID value.
The 32 character value can be located physically on the drive's label.
The value is case sensitive. Enter it as it appears on the label or scan the 2D barcode next to the value.
The value may appear as two values on multiple lines.
Enter a single value with no spaces or new lines.
Enter PSID [(q) to quit] C171D0CB20AE5B24FC9E89DE9CA82322
Error Selected Drive contains a partition. Remove all partitions to proceed.
SSDProAdminTool_2.0.2.401_win32.exe psid_revert -intelssd CVLY63030265180C
Community Manager
Hi anson1999,
I see that you cannot complete the task because the drive contains a partition according to the error message. I'm aware of the fact that you cannot delete the partitions so please let me investigate if there is something else we can do about it.
Have a nice day.
Diego V.
SMuns
Hi Diego V,
Would Diskpart work?
Shawn.
AWong22
Hello Shawn,
I finally fix the issue. Here is the steps.
1. Plug the SSD the computer directly and boot the WinPE
2. CMD (Admin), Diskpart
3. Select target disk and delete all the partitions with override
4. Run the SSDProAdmin psid_revert -intelssd 0 and enter the PSID which can be found on the label
5. After the the Opal will be disable
SMuns
Good it worked for you.
Shawn
Community Manager
Hi ansonw1999,
It's great you were able to recover the drive.
Thanks Shawn for sharing the suggestion of using Diskpart.
Diego V.
