Hello doug.embrey,
The Intel® Solid-State Drive 750 Series is a high performance consumer drive, it is not supported in enterprise operating systems. Please check the http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-750-spec.pdf Intel® SSD 750 Series Product Specification for additional details.
For servers and enterprise systems, you might want to consider drives from the http://www.intel.com/content/www/us/en/solid-state-drives/intel-ssd-dc-family-for-pcie.html Intel® Solid-State Drive Data Center Family for PCIe*, which includes thehttp://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3500-seri... Intel® Solid-State Drive P3500 Series, http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3600-spec... Intel® Solid-State Drive P3600 Series and http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec... Intel® Solid-State Drive P3700 Series.
These drives are PCIe* Gen3 X4 devices. Your server and other current systems would not be able to do a Hardware RAID using PCIe NVMe drives. RAID configuration can be made via software at the OS level.
In order to confirm the compatibility between your Server and these SSD's we would advise you to contact http://www8.hp.com/us/en/troubleshooting.html HP support.
These are the standard requirements in order to use the PCIe NVMe drives (please check the Product specifications linked before for additional details):
- UEFI 2.3.1
- PCIe* Gen3 X4
- 2.5-inch Form Factor
15mm Z-height
8639-compatible connector
- AIC Form Factor
Half-height, Half-length
Single slot x4 connector
Hello doug.embrey,
- UEFI 2.3.1
- PCIe* Gen3 X4
15mm Z-height
- AIC Form Factor
