Hey all,
So I followed Intel's advice (I'm not sure it's an advice really, as it just describes HOW to do it, not the purpose), from here:
"Disable write caching on Intel® Solid-State Drives"
: http://www.intel.com/support/ssdc/hpssd/sb/CS-031690.htm http://www.intel.com/support/ssdc/hpssd/sb/CS-031690.htm
And the results are the OPPOSITE as what's intended I think...
Check these images:
So hmm.. I'm not sure what's going on..
The drive is a 80GB G2, and OS is XP 32Bit with AHCI driver. Please advise, why would Intel recommend this? o_O
Sorry, here are the images:
http://videoff7.free.fr/wce.png/">
http://videoff7.free.fr/wcd.png/">
The drive is a 80GB G2, and OS is XP 32Bit with AHCI driver. Please advise, why would Intel recommend this? o_OV
Your supposition's correct, Intel does not recommend disable write caching, quite on contrary, it's only an "exercise".
You can see that in: http://www.intel.com/support/ssdc/hpssd/x25m/sb/CS-031542.htm http://www.intel.com/support/ssdc/hpssd/x25m/sb/CS-031542.htm
v.
valdir, thanks for your answer.
I agree with you that write-caching should be left ENABLED.
Then, this page is very confusing: http://www.intel.com/support/ssdc/hpssd/sb/CS-031690.htm http://www.intel.com/support/ssdc/hpssd/sb/CS-031690.htm
I think Intel should definitely specifiy that it should NOT be done! (then what is the purpose of this tutorial, I wonder...).
