I7-14700K processor crashing
I bought my PC from Best Buy a couple of years ago in July and I’ve had issues with my PC crashing a lot. I had Geek Squad take a look at my PC and they said all my hardware is good, They tested everything with new parts minus the CPU, which they concluded is most likely the case. I wouldn’t expect my CPU to fry so quickly, I ran my PC on default settings.
We understand your concern regarding the frequent system crashes, especially considering that your PC was purchased only a couple of years ago and has been operating under default settings without any manual overclocking.
We also acknowledge the troubleshooting efforts made through Best Buy Geek Squad, including testing the other hardware components using replacement parts and identifying the processor as the suspected cause of the issue.
We appreciate you taking the time to have your system diagnosed. To help us investigate further and determine whether the processor could be contributing to the crashes, could you kindly provide the following details?
1. Processor and System Configuration:
  • Exact Intel® processor model:
  • Motherboard manufacturer and exact model:
  • Current BIOS version:
  • RAM capacity and configuration:
  • Graphics card model:
  • Windows version and build:
2. Issue Details:
  • When did you first start experiencing the random system crashes?
  • Does the system crash during gaming, heavy workloads, idle usage, or even during normal activities?
  • Does the system display a Blue Screen of Death (BSOD), freeze, restart automatically, or shut down completely?
  • If a BSOD appears, could you share the exact Stop Code?
  • Have you noticed any error messages or warning indicators before the system crashes?
3. Troubleshooting Performed:
  • Could you confirm which hardware components were tested or replaced by Best Buy Geek Squad?
  • Did Geek Squad perform any processor-specific diagnostics? If so, could you share their findings or diagnostic report?
  • Have you tested your processor in another compatible motherboard?
  • Alternatively, have you tested another compatible processor in your current motherboard?
  • Have you updated the motherboard BIOS to the latest available version?
4. BIOS and Processor Settings:
Could you please confirm whether your processor is currently operating with Intel Default Settings, without any manual overclocking, undervolting, or voltage adjustments?
These details will help us better understand the reported symptoms and identify the appropriate troubleshooting or warranty resolution.
We appreciate your cooperation and look forward to assisting you further
The i7-14700K has had some known stability issues, so I’d recommend checking that your motherboard has the latest BIOS with Intel’s updated microcode. Also, make sure the BIOS is using Intel Default Settings instead of any motherboard performance or overclocking profile. If the crashes continue, try running Intel Processor Diagnostic Tool and check for any errors. Since Geek Squad already tested the other hardware, it may be worth contacting Intel Support to discuss your CPU warranty options.
