Intel Core Ultra 9 285k temps
First of all, here are my PC specs:
Motherboard: Gigabyte Z890 EAGLE
CPU: Intel Core Ultra 9 285k
CPU Cooler: MSI MAG Coreliquid 240r v2
Memory: Corsair Vengeance 4x16GB DDR5 5600Mhz
GPU: Gigabyte RTX 5070 Ti WindForce OC
SSD: Samsung 980 PRO 1TB
OS: Windows 11 24H2
The issue started after getting the CPU, I had i7-12700KF before, one time temps jumped to 104c in the boot process and CPU was throttled, I tried Intel XTU and got 105c and CPU throttled, the weird things is in games it doesn’t go over 85c.
I made sure that the CPU Cooler is working, felt the vibration on it, made sure fans are running and sped up after the temps went high, everything is connected properly.
Note: This a clean installation of Windows 11
What could be the issue?
Hi Security,
Have you tried updating your BIOS to the latest?
Did you do any recent changes?
Did you overclock the processor?
Is the issue happening on default settings?
Is the issue also happening on the i7-12700KF?
What are the troubleshooting steps that you tried so far?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
Yes, BIOS is latest version
Upgrading my PC
No
Yes
No, wasn’t happening
Reinstalled cooler, changed thermal paste, changed air flow, rewired cables, etc..
Info attached.
info.txt (231 KB)
Hi Security,
Thank you for the feedback. Please confirm if you’ve already did the troubleshooting on the Overheating Symptoms and Troubleshooting for Intel® Boxed Processors.
Additionally, please follow the The Intel® Processor Diagnostic Tool Overview, Download and let me know the results.
Archie D.
I went ahead and changed the CPU Cooler, and the problem disappeared; it appears that the old one has this common issue that it clogs after 1-2 years.
Hi Security,
I’m glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior.
Since the thread is now solved, I will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Archie D.
