Intel® Core™ Ultra X7 Processor 358H firmware
Hello! I have a panther lake system and I need a firmware file to re-install it since the original firmware got corrupted. Any source where I can obtain it?
I ran into something similar and I wouldn’t try to flash a standalone CPU firmware file, since Intel doesn’t really hand those out that way. In my experience that firmware comes bundled into the system or board maker’s BIOS update, so I’d start with the support page for your exact laptop or motherboard model and check for a BIOS update there. If you can share the exact model and what got corrupted, that should make it easier to point you to the right update.
@Ezuniga,
If this Panther Lake system is an Intel branded product, be aware that Intel does not normally provide standalone firmware (such as .BIN) files as Intel firmware loads normally require factory-level branding and security updates. If you find a second-source for such a file, it will be extracted from another instance of this product (via flash device programmer, for example), and thus will be branded for that other instance, making your system essentially a copy of theirs. Intel does not provide field-level tools for the re-branding of such a copy; you would thus be on your own from that point onwards.
…S
