We appreciate you reaching out to us regarding the reported issue.
Please be informed that the old BIOS was removed as Intel recommends using the latest firmware update package, which is available on the Download Center.
You can get the old BIOS packages from the Intel RDC site below, but the document will require CNDA.
For further details, you can refer to the link below on how to register for a Developer Zone Premier account:
Might you point out where you have found a solution?
@Fikri_Intel : I already signed up for an standard account, but I am not able to find the needed Upgrades. The Board I need to update to new Firmware, MBC, … usese the following Versions atm:
BMC Firmware Build Time : Thu Feb 8 23:10:05 2018BIOS ID : SE5C620.86B.00.01.0013.030920180427BMC FW Rev : 1.43.660a4315Backup BMC FW Rev : 1.43.660a4315Build ID : 660A4315SDR Package Version : 1.43Mgmt Engine (ME) FW Rev : 04.00.04.294Baseboard Serial Number : BQWF81400118
We see that you have mentioned you have a RDC standard account. Please note that you need a RDC premier account to access the older BIOS versions.
You can refer to below link for How to Apply for an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) Premier Account.
Additionally, please note that standard Corporate Non-Disclosure Agreement (CNDA) is required to access the RDC premier account.
If you do not have an active CNDA, we recommend contacting one of your Intel® Representative / Distributors from your organization, who will be able to assist you in getting the CNDA signed with Intel.
Sachin KS
Hi Sachin
We do not have an active CNDA. As we are a quite small company we do not have a special representative in our organization.
I already contacted the manufacturer of the server hardware (Tarox in Germany) but they were not able to provide the bios versions.
As you have informed that you do not have an Intel representative for your organization, we request you to contact your intel sales point of contact or Intel distributors in your location regarding this.
You can know about the list of distributors in your location in the below link.
I’m also looking for the older BIOS/firmware versions required to update an Intel S2600WF/R2312WFTZS system from an older firmware level. It seems these files are no longer available through the standard Intel Download Center and require RDC Premier/CNDA access. If anyone has managed to obtain the upgrade chain without a Premier account, could you please share where the files are available? Any help or guidance would be greatly appreciated.
