cancel
Showing results for
Search instead for
Did you mean:
Client/Server example for DE2 uClinux
A simple example for communicating over ethernet using sockets and TCP/IP is given here.
Compile the server.c on server machine using: gcc server.c -o server
Compile the client.c on server machine using: nios2-linux-uclibc-gcc -elf2flt client.c -o client
Copy client to DE2 or use nfs mounted share.
Run server as: ./server 8888 # where 8888 is arbitrary port above 1024, wait for client
Run client as: ./client 192.168.1.10 8888 # where 192.168.1.10 is server IP addr, send message to server
Server program server.c (attached):
/* A simple server in the internet domain using TCP
The port number is passed as an argument */
#include <stdio.h>
#include <stdlib.h>
#include <strings.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
void error(char *msg)
perror(msg);
exit(1);
int main(int argc, char *argv[])
int sockfd, newsockfd, portno, clilen;
char buffer[256];
struct sockaddr_in serv_addr, cli_addr;
int n;
if (argc < 2) {
fprintf(stderr,"ERROR, no port provided\n");
exit(1);
sockfd = socket(AF_INET, SOCK_STREAM, 0);
if (sockfd < 0)
error("ERROR opening socket");
bzero((char *) &serv_addr, sizeof(serv_addr));
portno = atoi(argv[1]);
serv_addr.sin_family = AF_INET;
serv_addr.sin_addr.s_addr = INADDR_ANY;
serv_addr.sin_port = htons(portno);
if (bind(sockfd, (struct sockaddr *) &serv_addr,
sizeof(serv_addr)) < 0)
error("ERROR on binding");
listen(sockfd,5);
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd, (struct sockaddr *) &cli_addr, &clilen);
if (newsockfd < 0)
error("ERROR on accept");
bzero(buffer,256);
n = read(newsockfd,buffer,255);
if (n < 0) error("ERROR reading from socket");
printf("Here is the message: %s\n",buffer);
n = write(newsockfd,"I got your message",18);
if (n < 0) error("ERROR writing to socket");
return 0;
Client program client.c (attached):
#include <stdio.h>
#include <stdlib.h>
#include <netdb.h>
perror(msg);
exit(0);
int sockfd, portno, n;
struct sockaddr_in serv_addr;
struct hostent *server;
char buffer[256];
if (argc < 3) {
fprintf(stderr,"usage %s hostname port\n", argv[0]);
exit(0);
portno = atoi(argv[2]);
if (sockfd < 0)
server = gethostbyname(argv[1]);
if (server == NULL) {
fprintf(stderr,"ERROR, no such host\n");
exit(0);
//bzero((char *) &serv_addr, sizeof(serv_addr));
memset((char *) &serv_addr, 0, sizeof(serv_addr));
//bcopy((char *)server->h_addr, (char *)&serv_addr.sin_addr.s_addr, server->h_length);
memcpy((char *)&serv_addr.sin_addr.s_addr, (char *)server->h_addr, server->h_length);
if (connect(sockfd,(struct sockaddr *)&serv_addr,sizeof(serv_addr)) < 0)
error("ERROR connecting");
printf("Please enter the message: ");
//bzero(buffer,256);
memset(buffer,0,256);
fgets(buffer,255,stdin);
n = write(sockfd,buffer,strlen(buffer));
if (n < 0)
n = read(sockfd,buffer,255);
if (n < 0)
printf("%s\n",buffer);
return 0;
This code was modified from http://www.cs.rpi.edu/~moorthy/Courses/os98/Pgms/
Version history
Last update:
‎06-24-2019 11:51 PM
Updated by:
Contributors
