Intel® Optane™ Memory
1391 Discussions
gigabyte h270 gaming3 "intel optane ready" can't make it?
fmari2
hey guys, first forgive me please, english is not my language (french)
i'm trying to make my optane device (MEMPEK1W016GA) working on my gigabyte H270 gaming3 + intel core i5 7600k
bios updated with latest version
turned to UEFI Bios mode
still get the same error message when i try to instal "SetupOptaneMemory" software => "bios mode not supported...
your system's BIOS setup is not compatible with intel optane memory"
as i'm not into hardware settings, is anyone can help me to fix it? speaking to me as i would be 5 years old...
not sure what you need, so i join what i think usefull, ask me anything else if needed,
thanks
Hi sQuall,
Thank you for contacting our support community. We understand your situation regarding your Intel® Optane™ Memory.
As per SSU and Optane™ logs, it seems that your BIOS is set to "Legacy Mode". In order to change the configuration to the "UEFI Mode", we recommend you to follow the next steps:
1- Backup all files on your system.
2- Make sure you have the Windows(R) 10 creator's update installed on your system and convert the partition table from MBR to GPT with MBR2GPT.exe in order to allow the system to boot after the BIOS change, please follow the next steps:
A- Open Command Prompt with administrator privileges
B- Issue the following command: mbr2gpt.exe /convert /allowfullOS
3-Shut down and boot into your BIOS
4- Press F7 to go to the advanced mode.
5-Go to BIOS and under the BIOS option check the following configuration:
-CSM Support: Disabled
6-Go to the peripherals and check the following configuration:
-SATA Mode Selection : "Intel RST Premium with Intel(R) Optane(TM) system acceleration".
-Use RST Legacy OROM: disabled.
-PCIe Storage Dev On Port # (the port number where Optane(TM) is connected): RST Controlled.
7-Press F10 to save and apply the changes.
Note: Automatic repair may show up and it is expected.
Please let us know the outcome of your situation.
Junior M.
fmari2
hey junior M
thanks for your help
step 5 : my bios does not show : CSM supported, so i can't set to disabled
step 6 : sata mode selection to intel RST premium with intel... OK
use rst orom disabled OK
can't set the port number for the pcie storage
i tried even though to save and exit : can't boot, says something like insert proper boot device...
i join some screenshots... but i guess that won't help...
fmari2
one more sreenshot
Hi sQuall,
Thanks for the screenshots attached.
It seems that your system stills set to the Legacy mode based on the disk management screenshot and that is why you can not boot when applying the BIOS changed. We recommend you to follow the next steps so you can boot after applying the BIOS settings:
3-Shut down and boot into your BIOS and made the changes suggested above.
Also, the option "-PCIe Storage Dev On Port # (the port number where Optane(TM) is connected): RST Controlled." will be only available if the SATA Mode Selection is equal to: "Intel RST Premium with Intel(R) Optane(TM) system acceleration".
It seems that the equivalent for the CSM option is the Windows 8/10 Features option that is under the BIOS settings, please make sure it is set to Windows 8/10.
Junior M.
fmari2
Hi Junior M,
Thanks again for your help, and for being patient...
my apologies... wrong typing on command prompt... i did it again then it worked
but
CSM support : DISABLED => OK
SATA mode selection : Intel RST Premium with Intel(R) Optane(TM) system acceleration => OK
Use RST legacy OROM : DISABLED => OK
PCIe Storage Dev On Port 21 : RST CONTROLLED => OK
saved and exit
automatic repair... then restart... Erpp.... no OS, back to BIOS menu "ROM Image is not loaded ... ROM Image update denied"
i set back my settings then i can enter windows to let you know...
screenshots attached...
regards,
sQuall
fmari2
Hi sQuall,
It seems that the process we had provided didn't work because after the automatic repair you were supposed to be able to boot Windows*. At this point, our recommendation is to back up your data, physically remove the Optane(TM), set the BIOS with the proper configuration for Optane(TM) we have provided before:
Use RST legacy OROM: DISABLED => OK
After that, we recommend you to reinstall Windows(R) 10 so it will be set properly for Optane(TM) in GPT mode and also your BIOS will be set to UEFI mode. Also, during the Windows(R) 10 partition set up, we recommend you to leave 5MB of unallocated space.
Junior M.
fmari2
it works fine now
thank you so much
best regards,
sQuall
Hi sQuall,
Thanks for the reply.
We are glad to hear that your situation has been resolved.
If you have further questions then feel free to contact us again.
Junior M.
