Community
cancel
Showing results for
Search instead for
Did you mean:
Ironclad17
Dualport ssd D3600 in pcie 3x4 port
Is anyone familiar with how dualport ssds behave when connected to single device? I'm unclear if it will operate at full pcie 3x4 or if it's limited to pcie 3x2 with a single connection. I've also read that if the dual port sense pin doesn't receive a signal it will operate in single port mode at full 3x4.
JosafathB_Intel
Hello, Ironclad17.
Thank you for contacting Intel® Memory and Storage support.
As we understand, you need assistance related to your Intel® SSD DC D3600 Series. If we infer correctly, we will appreciate it if you can review the following information:
-We do not support or recommend the usage you are referring to in your post.
As mentioned on https://ark.intel.com/content/www/us/en/ark/products/88730/intel-ssd-dc-d3600-series-2-0tb-2-5in-pci...
Interface
PCIe NVMe 3.0 2x2 dual port
Any other port or adapter is not supported. We advise you to contact your motherboard OEM (original equipment manufacturer) to check if your system supports this SSD.
- As mentioned on the Intel® Dual-Port NVMe* SSDs | See the Difference Fast Makes:
https://www.intel.com/content/www/us/en/products/docs/memory-storage/solid-state-drives/dual-port-pc...
Matching high performance with high reliability, the Intel® SSD DC D3700/3600 series delivers the first super-fast dual-port NVMe* SSD, with designed redundancy, end-to-end data protection, and data integrity built on the latest industry standards.
-Intel Dual-Port SSD can be identified with the that "D" before its series number means that the drive is Dual Port, for example:
Intel® Optane™ SSD DC D4800X Series
Intel® SSD DC D3700 Series
The Intel® SSD DC D3600 Series and Intel® SSD DC D3700 Series are EOL (end of life) products. If you are interested in buying dual-port SSDs, we advise you to contact your reseller to check for availability.
We will follow up with you again on Wednesday, the 5th of May 2021, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
Josh B.
Intel® Customer Support Technician.
JosafathB_Intel
Hello, Ironclad17.
We noticed you have another thread open related to the same issue. We will proceed to close this thread as a duplicate.
Jos B.
