Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Help unistall program!
Plyz help why i can unistall program?
PWert
Valued Contributor I
Did you try to reinstall the program and then uninstall it? Regards. Peter
Community Manager
No work install becouse he say "A newe version of Interl(R) PROSet/Wireless Software for Bluetooth(R) Technology is already installed. Setup will no exit."
PWert
EliteZ - I would recommend you repost your question on the wireless forum. Here is the link /community/tech/wireless http://communities.intel.com/community/tech/wireless . I found this thread but am not sure it applies to you. http://www.intel.com/support/network/sb/CS-029916.htm http://www.intel.com/support/network/sb/CS-029916.htm Regards. Peter
RGiff
Honored Contributor I
Have you tried going into Device Manager and disabling the device , Than try uninstalling the software. Sometimes software will not uninstall when it is in use. But be sure to have the new program on your desktop ready to install.
