Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel 520 SSD installation steps
Hi
I've got a 520 arriving today for use as my OS drive and I want to make sure I've got my installation steps correct:
1. In BIOS, set SATA mode to ACHI
2. Install Windows 7
3. Disable superfetch
4. Make sure no disk defragmentation scheduled
5. Install rapid storage technology driver
6. Download and install Intel SSD Toolbox
Does that sound about right? Am I missing any steps or would you do any of the steps in a different order?
What about Secure Erase? Firmware update? AES 256 encryption? Not sure if I need to do anything regarding these. Will the drive be encrypted without me doing anything?
Community Manager
1. Go to BIOS, set boot priority 1. CD-ROM 2. HDD
2. Unplug your old HDD (leave it in your case, so you can re-connect later). Important you disconnect this as Windows 7 might see this drive first. Make a note which SATA port your HDD was was connected too.. best if its a native Intel controller, and its SATA 2 or 3..
3. Replace with your new SSD.
4. Insert Windows 7 CD-ROM
5. Start PC, press DEL to go to BIOS. Set to ACHI (you should see the Intel in the boot priority list number 2 now), Save.
6. Choose Custom Install of Windows 7 - let it do the rest
7. Go to Intel website- Install Tool Box 3.02 - this will sort out all the settings like Superfetch ect...
8. You're good to go.. run the Tool box features like optimizer etc..
good luck
Community Manager
Thanks! All worked well...except the driver for the actual SSD is from Microsoft. Is there an Intel driver?
I've already installed the IRST driver for the SATA controller.
Community Manager
Micorsoft took care of the install via Windows 7. Make sure you download the Intel tool kit 3.02
ARebe
"1. In BIOS, set SATA mode to ACHI"
Dont you mean 'AHCI' ?
Regards.
