problems of DM9000 on DE2
i am a beginner for FPGA and i work with linux-mmu on the de2 board.
https://www.alteraforum.com/forum/attachment.php?attachmentid=2777
when the system on de2 is power on,the sysinfo is
https://www.alteraforum.com/forum/attachment.php?attachmentid=2778
when in ifconfig the eh0 the following info is present
https://www.alteraforum.com/forum/attachment.php?attachmentid=2779
i have confused for 5 days ,what can i do
thanks
I never used DM9000 but on nioswiki there is a good section about...
check
http://www.nioswiki.com/index.php?title=operatingsystems/uclinux/ethernet&highlight=dm9000
Anyway, I would double check the sopc configuration (as indicated in nioswiki)...
The driver seems loaded but, obviously, not working...
Sorry :p
Carlo
thank you very much
i will check again
Dear wang!
I met the same problem as you .Have you solved it successfully?
I am relly puzzled now.
--- Quote Start ---
Dear wang!
--- Quote End ---
:) i have fix it
add those lines at the bottom of setup.c
#if defined(CONFIG_DM9000)
# include <linux/dm9000.h>
static struct resource dm9k_resource[] = {
[0] = {
.start = DM9000A_BASE,
.end = DM9000A_BASE + 3,
.flags = IORESOURCE_MEM,
[1] = {
.start = DM9000A_BASE + 4,
.end = DM9000A_BASE + 4 + 3,
[2] = {
.start = DM9000A_IRQ,
.end = DM9000A_IRQ,
.flags = IORESOURCE_IRQ | IRQF_TRIGGER_HIGH,
static struct dm9000_plat_data dm9k_platdata = {
.flags = DM9000_PLATF_16BITONLY,
// default MAC addr
.dev_addr = {01,01,01,01,01,01},
static struct platform_device dm9k_device = {
.name = "dm9000",
.id = 0,
.num_resources = ARRAY_SIZE(dm9k_resource),
.resource = dm9k_resource,
.dev = {
.platform_data = &dm9k_platdata,
static int __init dm9k_device_init(void)
/* customizes platform devices, or adds new ones */
platform_device_register(&dm9k_device);
return 0;
arch_initcall(dm9k_device_init);
# endif
Nice of you to give reply .I have tried your method but unfortunately failed.Thank you all the same! maybe I met other problems.
Ensure that your .v top file really connects the DM9000 signals from the SOPC core to the outer FPGA pins. Some Altera design examples lack this conection.
