Pci Bridge Oc Core
Hi, have even oney used Open Cores PCI Bridge core? Is it reliable? Can it achive good transfer speed? Does any one ever implemented it on a Altera FPGA? Thank you
I did and it is working fine. I´m not sure if it is able to handle DMA transfers, I haven´t tested this since yet. The Core itself works properly good.
Any recomendations for Linux drivers (2.6)?? Have you tryed it as a master? Any idea of maximum throughput?
Thank you!!
Hi again,
I only tried it as a Slave Bridge under Windows, so I can´t help you out here. It just works as normal PCI device. Like I said I haven´t tried the DMA or burst transfers on it.
Hi, i am trying to use OpenCores PCI Bridge but i have some doubts.
Whats exactly is the Image Address and how it works?
When i am receiving some information on PCI Target, how can i define the
WishBone Slave that is being addressed?
When i am sending some information with a WishBone Master to the Bridge
Slave, how can i define to which PCI on the BUS i am addressing?
Thank you!
