Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
S4500 smart recommended tresholds
KPump
Is there any documentation regarding Intel SSD smart value recommended thresholds to monitor?
I'm am particularly interested in DC S4500's as support article mentions that for example "Pending Sector Count" will be much higher than on older gens
and will change often and can be ignored to some level.
Do I even need to have Nagios NRPE smart_check scripts poke these values on S4500's and if I need then what threshold should be set there?
support article ref:
* https://www.intel.com/content/www/us/en/support/articles/000027708/memory-and-storage/data-center-ss... https://www.intel.com/content/www/us/en/support/articles/000027708/memory-and-storage/data-center-ss...
Rudais
Community Manager
Hello Rudais.
Thank you for contacting Intel Technical Support.
As we understand, you are interested in learning more about SMART attributes related to your Intel® SSD Data Center Family DC S4500 Series. If we infer correctly, we recommend you to visit the following link:
https://www.intel.com/content/www/us/en/support/articles/000023512/memory-and-storage/data-center-ss... https://www.intel.com/content/www/us/en/support/articles/000023512/memory-and-storage/data-center-ss...
The https://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/Intel_SSD_Smart_Attrib_... Intel® Solid State Drive Data Center for SATA SMART Attributes (PDF) includes recommendations and a table listing the SMART attributes supported by the Intel Data Center SSDs for SATA.
The Intel's Data Center Tool (DCT) can be used to read out the SMART attributes to download this tool please follow this link:
https://downloadcenter.intel.com/download/27863/Intel-SSD-Data-Center-Tool https://downloadcenter.intel.com/download/27863/Intel-SSD-Data-Center-Tool
We hope you find this information useful.
Josh B.
Intel Customer Support.
Community Manager
Hello Rudais.
Josh B.
KPump
Thanks for reply.
I hadn't yet looked into viewing smart via DCT linux version. It looks that this will be much better option to check drive health with than standard smartmontools - smartctl.
As I can just run periodical selftests via cron and check "DeviceStatus" value and maybe separate attribute "Action" values. That way I don't have to do any interpretation as I can just
check the statuses that DCT outputs.
Now just to create NRPE script for that.
