cancel
Showing results for
Search instead for
Did you mean:
SSD DC P3700 not found
TRump
New Contributor
I bulid a DC 3700 SSD in a Fujitsu server. It seems the server is not able to find the drive. The LED lights green, the BIOS shows the slot in use. I tested to boot the server with the firmware update program, it didn't find any SSD. Any idea?
Should I see a meesage from teh SSD during the bootprocess, like the screens from the HBA or raidcontroller?
5 REPLIES 5
CChon3
New Contributor III
New Contributor III
The update tool cannot see the SSD if the nvme driver is not installed.
Can you run the following commands one by one and post the results here:
lspci | grep 0953
modinfo nvme
lsmod | grep nvme
