Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
SSD Toolbox incorrectly reports a RAID with Intel SSD 330 on AMD 880G/SB850 chipset
Recently I bought an Intel 330 120 GB SSD, which I installed windows 7 on, when i try to run the Intel SSD optimizer I get an error ...
Error: RAID array detected. If RAID array not present, reboot and try again. ... but when i run fsutil behavior query DisableDeleteNotify it returns 0 ... but if i fallback to the Windows 7 AHCI drivers it works correctly ... I've tried swapping ports, removing hard drives and nothing remedies this unless i fall back to windows 7 AHCI drivers
Tags (2)
