Community
cancel
Showing results for
Search instead for
Did you mean:
INorm
SSD335 won't boot, running W7 Ultimate 64bit
HELP I can't boot my PC, I can see SSD in BIOS, but PC doesn't see
jbenavides
Hello Zechariah47,
Try the following actions to try and resolve the issue, or at least, to determine what could be reason for it:
- Check the Boot order in the BIOS and make sure the SSD 335 is set as primary boot drive.
- Review the information reported by the drive in the BIOS and make sure it is being detected properly.
- Boot from a different hard disk or Operating System, using the SSD as a secondary drive. Check if the OS detects it and if you are able to see the data on it.
- Try accessing the drive in a different computer.
