This problem has been dismissed now multiple times with "Its below system requirements of the game, so we won't do anything about it" and "Go talk with the game developers about it" by moderators.
Source: https://community.intel.com/t5/Graphics/Lighting-issues-in-Helldivers-2/m-p/1575132
This problem is clearly something on the Intel's end, and it shouldn't be disregarded with these excuses because:
#1 - Even though Iris Xe 80EU and 96EU are below system requirements, there are benchmarks and reports showing it is playable on low settings (some found on the aforementioned threads). Thus, there is probably a lot more customers disapointed with the situation that are just not voicing their concerns, and probably looking at the competition's integrated graphics that is not suffering from this problem.
#2 - This could be a more widespread problem affecting other graphics products from Intel that are above minimum requirements of the application.
#3 - If every other gpu brand and other Intel products are not having this problem, it is most probably not the game developers fault and they can do nothing about it.
#4 - Regardless of being an older architecture, it is still under support and there is no excuse to have flawed drivers. This could well be an easy fix, but the people responsible for bringing it higher up to Intel's driver developers just refuse to do it.
I can back this up with my experiences. My laptop matches the game requirements in every except the graphics card. My game runs at a decent framerate on medium to high graphics settings, and I have had no issues with grashing or lag, but I still deal with the fog/lighting problem.
I'm using an ASUS Zenbook Pro 15 OLED
Windows 11 Home
Intel 12th gen i7
Intel Iris Xe Graphics
16gb RAM
512 SSD
My problem doesn't seem to be that the graphics card can't run the game, but that there's a bug causing it to create more fog in the environment tan there should me, which makes it very difficult to see. The pictures in the examples given above are exactly what I am experiencing too.
Tengo exactamente el mismo problema Helldivers 2 corre perfectamente sin lag o retrasos pero el problema es con la iluminacion esto esto es un problema del controlador grafico por favor solucionenlo.
Hello Skuva,
We sincerely appreciate your enthusiasm for improving the integrated iris graphics card performance with the Helldivers 2.
Please provide the following details so I can gather more information and provide you with a troubleshooting step. Just a heads up: once the troubleshooting steps that I have provided do not work, we will raise our case with our engineers for further assistance.
- Please provide a video of Helldivers 2 when you are playing the game so we can check the actual issue.
- What troubleshooting steps have you already tried? so we can avoid repeating them.
- Please generate an SSU report to help me further analyze important details on your system, such as the OS build number, graphics driver version, errors logged in the system, etc. To generate the SSU report, please refer to the article How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
We look forward to your response!
Thank you, and have a great day ahead!
Carmona A.
Video and SSU.txt below
I made the video in the tutorial mission because it serves as a good benchmark and is very easy to compare to other footage online, as the map and lighting is always the same. Compare it to other tutorial gameplays and you see how on Iris Xe there is no lighting over the character and scenario, or as others say, its way too dark and foggy. Also notice how the problem doesn't occours in the ship (at the very beginning), only during missions.
Troubleshooting steps attempted:
- Windows 11 is fully updated (non-insider).
- Fresh install of Helldivers 2 with all DirectX and Intel shader cache cleared.
- Tried all the game’s graphics presets.
- Tried drivers: 31.0.101.5444 Beta; 31.0.101.5382 WHQL; 31.0.101.5333 WHQL; Samsung’s official driver (very old).
- Multiple driver installation processes: Intel’s advised one (install without cleaning); Intel’s Clean install; And DDU.
EDIT: Here is a side by side shot to show it clearly (normal <-----> Iris Xe).
Hello Skuva,
Thank you so much for providing the information that we have requested.
Upon reviewing the troubleshooting procedures you have already completed, it appears that you have done an excellent job on your end. As such, I will now raise the issue with our engineers.
Once I have our engineers response, I will post it in this thread.
Have a fantastic day, and thank you very much for your patience and understanding!
Carmona A.
I know these things take time, but can we get an update?
Exactly. I've been in contact with an intel support technician for the last month and a half, and it took a month of back-and-forth troubleshooting for them to start "replicating the issue" and for the last two weeks, its just been delay after delay, while telling me to update my graphics driver even though the patch notes clearly don't target the issue, nor is it even mentioned in the "known issues" section.
Hello Skuva,
We are truly thankful for your patience while you are waiting for our update.
According to our senior engineers, they have tried testing this game, but after a few moments of rather low performance, they checked the game requirements. https://www.playstation.com/en-us/games/helldivers-2/pc/?country-selector=true.
And the game is not for our iGPU; we are sorry to inform you that the GFX team will not be able to do anything about it.
On the other hand, if those issues were addressed to Arc dGPU, then we could push it to the debug team because the equipment meets requirements.
By the way, if you need additional information, please submit a new question, as this thread will no longer be monitored.
Carmona A.
Hey look, they dismissed it again because "it's below minimum requirements". What a shame.
So they basically just launched the game, didn't like what they saw and dismissed the problem?
Good to know, this will help me make a better decision next time I need to buy or recommend a device with integrated graphics.
