Analyzers
5002 Discussions
如何进行整个flexran 5G l1app的vTune热点分析?
fachangguo
        目前已成功使用vTune软件进行sdk库的app分析,但在分析整个l1app时候遇到如下问题:尝试用vTune软件启动l1app,并用testmac跑相应业务信道用例(例如pucch format 2),但在vTune分析报告中没有看到对应的任务统计信息。
        想请教下如何用vTune进行整个l1app的热点分析?
AthiraM_Intel
Thank you for posting your question, however this is an English-only forum. I have translated your question and here is what resulted. Is this the question you were intending to ask?
"How to perform vTune hot spot analysis of the entire flexran 5G l1app?
The vTune software has been successfully used to analyze the app of the sdk library, but the following problems are encountered when analyzing the entire l1app: try to start the l1app with the vTune software, and use testmac to run the corresponding business channel use case (such as pucch format 2), but the vTune analysis report Did not see the corresponding task statistics.
Would you like to ask how to use vTune to perform hot spot analysis of the entire l1app? "
fachangguo
AthiraM_Intel
Thanks for the confirmation.
Could you please share the vtune version and details of error?
Also include the screenshots of the error.
Please share the complete steps to reproduce the issue and the commands you used?
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
