Analyzers
5005 Discussions
Parallel studio xe 2016 installation problem: vtss and sepdrv3_15 not allowed
Serge_M_1
Hello all,
I've encoutered two error messages when I have installed parallel_studio_xe_2016.
Windows7 does not allow to install vtss.ys and sepdrv3_15.sys because they are not registered and Windows7 requires registered drivers only.
I would like to use fortran compiler with Visual studio 2015; Are these two drivers absolutely needed ? What will be the drawbacks or unexpected problems without these drivers ?
Where can I find these drivers ?
Thanks by advance.
TimP
Those drivers would be needed for full functionality in vtune but not otherwise for Fortran. If your organization has set a local administrator policy to block installation of those drivers, one would think you could ask those who set the policy.
Serge_M_1
Hi Tim,
many thanks for your prompt answer!
Sincerely.
Steven_L_Intel1
I'm moving this question to the VTune Amplifier XE forum where VTune experts can comment further about the driver.
Peter_W_Intel
1. Open a cmd with administrator privilege
2. Change directory to vtune-installation-dir\bin64
3. You can run amplxe-sepreg.exe with parameters, "-s" to check drivers' status, "-i" to install, "-u" to uninstall
David_A_Intel1
Hey, Serge!  Check out this post at the top of the VTune Amplifier forum.  If you want to do hardware-based sampling, you need these drivers.
