I am trying to use VTune Amplifier XE 2015 to analyze application on Xeon Phi in the native mode.
Without VTune, the application on Xeon Phi runs normally (follows script: run.sh).
#!/bin/sh
export LD_LIBRARY_PATH=/tmp
/home/atrianta/clstmocrtrain
With VTune, the elapsed time is zero but VTune runs the application normally.
command : /opt/intel/vtune_amplifier_xe_2015.1.1.380310/bin64/amplxe-cl -v -collect=advanced-hotspots -target-system=mic-native:0 -- /home/atrianta/run.sh
results :
amplxe: Using target: mic-native:0
TOTAL time: 48.7338 secs = 0.812229 mins
amplxe: Using result path `/home/atrianta/r113ah'
amplxe: Executing actions 8 % Clearing the database
amplxe: The database has been cleared, elapsed time is 0.126 seconds.
amplxe: Executing actions 16 % Updating precomputed scalar metrics
amplxe: Raw data has been loaded to the database, elapsed time is 0.146 seconds.
amplxe: Executing actions 16 % Processing profile metrics and debug information
amplxe: Data transformations have been finished, elapsed time is 0.000 seconds.
amplxe: Executing actions 16 % Resolving module symbols
amplxe: Locating file `/lib64/ld-2.12.so' on the remote system
amplxe: Locating file `/usr/lib/debug/lib/modules/2.6.32-573.18.1.el6.x86_64/vmlinux' on the remote system
amplxe: Locating file `/lib64/libc-2.12.so' on the remote system
amplxe: Locating file `/usr/lib64/libcrypto.so.1.0.1e' on the remote system
amplxe: Locating file `/opt/intel/vtune_amplifier_xe_2015.1.1.380310/bin64/amplxe-runss' on the remote system
amplxe: Warning: Cannot locate file `/lib64/ld-2.12.so'.
amplxe: Executing actions 17 % Resolving information for `ssh'
amplxe: Warning: Cannot locate debugging symbols for file `/tmp/amplxe-tmp-atrianta/modules.mic-native_0/ssh/fb2032ff0cc20cd193fb35dcf39ca6a2/ssh'.
amplxe: Locating file `/boot/vmlinuz-2.6.32-573.18.1.el6.x86_64' on the remote system
amplxe: Warning: Cannot locate file `/lib64/libc-2.12.so'.
amplxe: Executing actions 18 % Resolving information for `libc-2.12.so'
amplxe: Warning: Cannot locate file `/usr/lib64/libcrypto.so.1.0.1e'.
amplxe: Executing actions 19 % Resolving information for `libcrypto.so.1.0.1e'
amplxe: Warning: Cannot locate file `/opt/intel/vtune_amplifier_xe_2015.1.1.380310/bin64/amplxe-runss'.
amplxe: Executing actions 19 % Resolving information for `amplxe-runss'
amplxe: Locating file `vmlinux-2.6.32-573.18.1.el6.x86_64' on the remote system
amplxe: Locating file `/boot/vmlinuz' on the remote system
amplxe: Warning: Cannot locate file `/usr/lib/debug/lib/modules/2.6.32-573.18.1.el6.x86_64/vmlinux'.
amplxe: Executing actions 24 % Resolving information for `vmlinux'
amplxe: Symbol resolution has been finished, elapsed time is 4.027 seconds.
amplxe: Executing actions 26 % Processing profile metrics and debug information
amplxe: Deferred data transformations have been finished, elapsed time is 0.012 seconds.
amplxe: Executing actions 27 % Setting data model parameters
amplxe: Data model parameters have been set, elapsed time is 0.006 seconds.
amplxe: Executing actions 35 % Updating precomputed scalar metrics
amplxe: Precomputing frequently used data has been finished, elapsed time is 0.032 seconds.
amplxe: Executing actions 41 % Saving the result
amplxe: Redundant overtime data has been discarded, elapsed time is 0.004 seconds.
amplxe: Raw collector data has been discarded, elapsed time is 0.000 seconds.
amplxe: Executing actions 50 % Saving the result
amplxe: Finalizing the result took 4.626 seconds.
amplxe: Executing actions 50 % Generating a report
General Exploration Metrics
Parameter r113ah
Collection and Platform Info
Parameter r113ah
Application Command Line /home/atrianta/run.sh
Operating System 2.6.32-573.18.1.el6.x86_64
Computer Name cedar
Result Size 1568205
CPU
Parameter r113ah
Name Intel Xeon Phi coprocessor
Logical CPU Count 8
Summary
Elapsed Time: 0.000
Event summary
Hardware Event Type Hardware Event Count:Self Hardware Event Sample Count:Self Events Per Sample
cycles 432000 108 4000
amplxe: Executing actions 100 % done
However, VTune analyzes without a problem /tmp/matrix.mic (from the example here: https://software.intel.com/en-us/articles/how-to-analyze-xeon-phi-coprocessor-applications-using-int...).
Can anyone help me figure out this problem?
To be more specific,
ldd command for my programm on PHI resulted on this :
linux-vdso.so.1 => (0x00007fffde5ff000)
libz.so.1 => /usr/lib64/libz.so.1 (0x00007fe086917000)
libimf.so => not found
libsvml.so => not found
libirng.so => not found
libintlc.so.5 => not found
libm.so.6 => /lib64/libm.so.6 (0x00007fe0866e8000)
libiomp5.so => not found
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007fe0863ee000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fe0861dc000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fe085fbf000)
libc.so.6 => /lib64/libc.so.6 (0x00007fe085c67000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007fe085a63000)
/lib64/ld-linux-k1om.so.2 (0x00007fe086b2b000)
So I had copied from /opt/intel/composer_xe_2015.1.133/compiler/lib/mic/ folder the "not found" libraries to /tmp/ of PHI (as I did with libiomp5.so for the matrix.mic example).
IF IT HELPS, I also ran VTune after i set the following variables :
export AMPLXE_LOG_LEVEL=TRACE
export AMPLXE_LOG_DIR=./log
but it stacks for my program on :
TOTAL time: 48.723 secs = 0.812051 mins
amplxe: Using result path `/home/atrianta/r118ah'
amplxe: The database has been cleared, elapsed time is 0.127 seconds.
amplxe: Raw data has been loaded to the database, elapsed time is 0.157 seconds.
amplxe: Locating file `/lib64/libpthread-2.12.so' on the remote system
amplxe: Locating file `/lib64/libselinux.so.1' on the remote system
amplxe: Warning: Cannot locate file `/lib64/libpthread-2.12.so'.
amplxe: Executing actions 17 % Resolving information for `libpthread-2.12.so'
amplxe: Executing actions 17 % Resolving information for `libc-2.12.so'
amplxe: Executing actions 18 % Resolving information for `libcrypto.so.1.0.1e'
amplxe: Warning: Cannot locate file `/lib64/libselinux.so.1'.
amplxe: Executing actions 19 % Resolving information for `libselinux.so.1'
amplxe: Executing actions 19 % Resolving information for `vmlinux'
and for matrix.mic on :
/opt/intel/vtune_amplifier_xe_2015.1.1.380310/bin64/amplxe-cl -v -collect=advanced-hotspots -target-system=mic-native:0 -- /home/atrianta/run1
Addr of buf1 = 0x7fd62df50010
Offs of buf1 = 0x7fd62df50180
Addr of buf2 = 0x7fd626ecf010
Offs of buf2 = 0x7fd626ecf1c0
Addr of buf3 = 0x7fd61fe4e010
Offs of buf3 = 0x7fd61fe4e100
Addr of buf4 = 0x7fd618dcd010
Offs of buf4 = 0x7fd618dcd140
Threads #: 228 OpenMP threads
Matrix size: 3840
Using multiply kernel: multiply1
Execution time = 32.422 seconds
amplxe: Using result path `/home/atrianta/r117ah'
amplxe: The database has been cleared, elapsed time is 0.125 seconds.
amplxe: Raw data has been loaded to the database, elapsed time is 0.161 seconds.
amplxe: Locating file `/lib64/libkrb5.so.3.3' on the remote system
when I ran with -no-auto-finalize flag the 2 above commands collection finishes normally.
Logs are in log.zip attachment.
I just added flag -knob collection-detail=stack-sampling and now it's ok.
full command : /opt/intel/vtune_amplifier_xe_2015.1.1.380310/bin64/amplxe-cl -v -collect=advanced-hotspots -knob collection-detail=stack-sampling -target-system=mic-native:0 -- /home/atrianta/run.sh
I don't know why nut it ran...
The point why -knob collection-detail=stack-sampling helped is that in this case another driver (and actually collection flow) works. But this is available only for advanced-hotspots..
Could you please provide the following output:
On host:
<VTune_install_dir>/bin64/sep -version -mic
and on target:
>lsmod | grep sep
Also I would highly recommend to update VTune to 2016 U4 - since 2015 version we had a bunch of fixes etc.
Thanks & Regards, Dmitry
Sampling Enabling Product version: 3.15 (private) built by patbbinn on Oct 26 2014 01:38:16
SEP User Mode Version: 3.15.5
>lsmod | grep sep
sep3_15 45337 0
It seems that in early versions "sep -version -mic" did not show info about available cards and drivers that are installed there etc.
Is it still possible to upgrade the VTune to VTune to 2016 U4 to see if it works and get output from "sep" command on this.
