Ethernet Products
4880 Discussions
On SRIOV interface (X553) unable to change the VF state from auto to enable.
bfaro1
  unable to change the VF state on SRIOV interface from auto to enable.
Is it allowed to change in X553 nics.
uname -a
Linux 4.14.52 #1 SMP PREEMPT Fri Nov 30 11:35:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
ip link show
10: enp6s0f0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 08:35:71:a0:a5:6b brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:00:00:00:00:00, spoof checking off, link-state auto, trust on, query_rss off
vf 1 MAC 00:00:00:00:00:00, spoof checking off, link-state auto, trust on, query_rss off
root:~# ip link set enp6s0f0 vf 0 state enable
RTNETLINK answers: Operation not supported
ethtool -i enp6s0f0
driver: ixgbe
version: 5.3.6
firmware-version: 0x8000084b
expansion-rom-version:
bus-info: 0000:06:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
modinfo ixgbevf
filename:    /lib/modules/4.14.52/updates/drivers/net/ethernet/intel/ixgbevf/ixgbevf.ko
version:    4.3.4
description:  Intel(R) 10 Gigabit Virtual Function Network Driver
author:     Intel Corporation, <linux.nics@intel.com>
lspci
06:00.0 Ethernet controller: Intel Corporation Ethernet Connection X553 10 GbE SFP+ (rev 11)
06:00.1 Ethernet controller: Intel Corporation Ethernet Connection X553 10 GbE SFP+ (rev 11)
06:10.0 Ethernet controller: Intel Corporation X553 Virtual Function
06:10.1 Ethernet controller: Intel Corporation X553 Virtual Function
06:10.2 Ethernet controller: Intel Corporation X553 Virtual Function
06:10.3 Ethernet controller: Intel Corporation X553 Virtual Function
Daniel_D_Intel1
Hello Bfaro1, Thank you for posting in Intel Ethernet Communities. Please try updating to the latest drivers ixgbe 5.5.3 and ixgbevf 4.5.2. Let us know if you are able to "enable" SR-IOV after this. If you have any other questions please do not hesitate to ask. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
Caguicla_Intel
Hello Bfaro1, Please let us know if you were able to update the drivers and enable SR-IOV. If you have any other question or concern, please let me know and I will be glad to help Best regards, Crisselle C Intel Customer Support Under contract to Intel Corporation
Caguicla_Intel
Hello Bfaro1, Please let us know if you were able to perform the recommendations above and enabled SR-IOV. If you have any other questions, please do not hesitate to ask. Best regards, Crisselle C Intel Customer Support Under contract to Intel Corporation
Caguicla_Intel
Hello Bfaro1, I hope the recommendations above worked for you. If not, please try to check with your system manufacturer for further assistance. If you have any other questions, please do not hesitate to ask. Best regards, Crisselle C Intel Customer Support Under contract to Intel Corporation
SRao6
I have the following PF driver:
# ethtool -i Eth1-1
driver: ixgbe
version: 5.6.1
firmware-version: 0x800008a4, 0.385.33
And I m still not able to disable the VF state.
# ip link set Eth1-1 vf 50 state disable
