Ethernet Products
4880 Discussions
SR-IOV vf rate
mche
hi,
I want to set the rx rate for one vf, currently i found txrate can be set by command: ip link set eth2 vf 0 rate 1000
i check the ip link help message, only see rate TXRATE in red color.
[root@c0209 ~]# ip link help
Usage: ip link add [link DEV] [ name ] NAME
ip link set { dev DEVICE | group DEVGROUP } [ { up | down } ]
[ vf NUM [ mac LLADDR ]
[ vlan VLANID [ qos VLAN-QOS ] ]
[ rate TXRATE ] ]
[ spoofchk { on | off} ] ]
[ query_rss { on | off} ] ]
[ state { auto | enable | disable} ] ]
i want to know how to set the rx rate for individual vf.
OS:centos7.2
NIC: Intel 82599ES
Many Thanks
majorin
majorinche: Thank you very much for joining the Intel® communities. We will do our best in order to provide the information you are looking for.
Just to let you know, I transfer your case to the proper department, an agent in there will get in contact with you to provide further assistance on this matter.
Alberto R
Hi Majorinche,
Thank you for posting in Wired Communities. I will further check on this.
Sharon
Hi Majorinche,
Further checking, I am sorry to inform you that RX rate limit is not supported.
Sharon
mche
