6367 Discussions
How to use duel core of cyclone V soc HPS by baremetal
CAlex
New Contributor II
like the topic said, any example,guide,instruction,idea is welcomed.
Reguards.
aikeu
Hi CAlex,
According to ARM documentation shown in the link below:
The ARM C libraries supply no thread management functions of their own so you must supply any that are required.
The ARM C libraries supply no thread-switching mechanisms of their own. This is because there are many different ways to do this and the libraries are designed to work with all of them.
https://developer.arm.com/documentation/dui0475/m/the-arm-c-and-c---libraries/multithreaded-support-in-arm-c-libraries/using-the-arm-c-library-in-a-multithreaded-environment
I think is better to work with linux unless you know what to consider in order to setup the environment properly for multithreading.
Aik Eu
aikeu
Hi CAlex,
I try to check with the team and we do not have any example of using dual core on cyclone V board.
Aik Eu
CAlex
New Contributor II
so the only way to use duel core on cycloneVsoc is to use Linux?
Reguards.
aikeu
Hi CAlex,
Aik Eu
aikeu
Hi CAlex,
I will close this thread for now.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Aik Eu
