Intel HD graphic如用在window10 上會沒有甚麽問題?
PLZ
Yes, you can use the Intel® HD graphic for Windows 10; however, bear in mind that if you have problems with it you will need to check with your system manufacturer and find out if your system supports Windows 10.
