Hello, I have a motherboard asrock h310m-G/M. 2, it has enters VGA/DVI/HDMI, I would like to know if I can simultaneously connect 3 monitors with extended screen
better you must read the user manual of motherboard , download from bellows site
http://asrock.pc.cdn.bitgravity.com/Manual/H310M-GM.2.pdf
Its bettor you should contact asrock customer care
No, you cannot. According to the spec sheet, only two connectors can be used simultaneously.
Poor motherboard design, if you ask me.
Topic Options
