After I updated to 15.0 on a very old MFC codebase on Windows I get a couple of these errors:
error : extra text after expected end of number
They are all in Message Maps for ON_NOTIFY_REFLECT or ON_NOTIFY_REFLECT_EX.
ON_NOTIFY_REFLECT_EX(NM_KILLFOCUS, OnKillfocus) ON_NOTIFY_REFLECT_EX(NM_SETFOCUS, OnSetfocus) ON_NOTIFY_REFLECT_EX(LVN_BEGINLABELEDIT, OnBeginlabeledit) ON_NOTIFY_REFLECT_EX(LVN_ENDLABELEDIT, OnEndlabeledit)
BEGIN_MESSAGE_MAP(CmM4_Footnotes_ExpandedTree, CmM4_TreeCtrl) //{{AFX_MSG_MAP(CmM4_Footnotes_ExpandedTree) ON_WM_CREATE() //}}AFX_MSG_MAP ON_NOTIFY_REFLECT_EX(LVN_INSERTITEM,OnUpdateTreeContents) ON_NOTIFY_REFLECT_EX(LVN_DELETEITEM,OnUpdateTreeContents) ON_NOTIFY_REFLECT_EX(LVN_DELETEALLITEMS,OnUpdateTreeContents) END_MESSAGE_MAP()
All that is code that has been unchanged for ages, I have to assume there is some compiler bug at work; anybody can confirm that or maybe have a suggestion for a workaround?
Are you using the /Qstd=c++11 option?
I only see the problem when user defined literals are enabled (which only happens by default in MSVC++ 2015 compatibility mode).
If so you can disable them with the /Qoption,cpp,--no_user_defined_literals option.
!% icl -c /Qoption,cpp,--user_defined_literals t.cpp
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Ve
rsion 15.0 Beta Build x
Built Jan 19 2015 12:59:50 by jward4 on JWARD4-DESK1 in D:/workspaces/15_0cfe/de
v
Copyright (C) 1985-2015 Intel Corporation. All rights reserved.
t.cpp
t.cpp(2): error: extra text after expected end of number
int i = 0x004E+0xBC00;
compilation aborted for t.cpp (code 2)
!% icl -c /Qoption,cpp,--no_user_defined_literals t.cpp
v
t.cpp
!% icl -c t.cpp
v
t.cpp
Judy
- « Previous
- 1
- 2
- Next »
/Qoption,cpp,--no_user_defined_literals does work for me as a work-around, that's good to know.
Dix
- « Previous
- 1
- 2
- Next »
