How do I remove Intel C++ Compiler integration from Visual Studio?
For Intel C++ compiler 11.0, you need to run the install script again. You select the modify option to select the component that you need to remove from the Intel C++ compiler installation.
For older version of Intel C++ compiler you can do it from Control panel Add or Remove programs.
Or run the "integrate.bat" at intelcompilerVS IntegrationC++VS2005 like:
>> integrate "VC8-dir" /u
Jennifer
Jennifer
