I'm trying to compile MPlayer with icc 9.0, but the compilation aborts with an internal compiler error. I've tracked down the problem to a file in the libavcodec subpackage of MPlayer. When compoiling this file, icc exists with the message:
(0): internal error: backend signals
compilation aborted for bug.c (code 4)
I am using icc 9.0.032:
icc -V
Intel C Compiler for 32-bit applications, Version 9.0 Build 20060222Z Package ID: l_cc_c_9.0.032
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
If you want to do any analysis, I've included the preprocessed file in the attachement so it can be compiled without the mplayer source code.
icc -V
I will have a look. Thanks for cutting the problem down to one file ;).
Message Edited by Mario on 05-16-2006 08:39 AM
