Intel® C++ Compiler
Problem with FFT code exemple and Visual Studio 2017
Gouyon_R_
Hello
I am trying to run the FFT code exemple. I am using Visual Studio with the intel 2019 compiler
this is my code
#include "pch.h"
#include <iostream>
#include "mkl_dfti.h"
int main()
	/* C example, float _Complex is defined in C9X */
	float _Complex x_in[32];
	float _Complex x_out[32];
	float y_in[32];
	float y_out[34];
	DFTI_DESCRIPTOR_HANDLE my_desc1_handle;
	DFTI_DESCRIPTOR_HANDLE my_desc2_handle;
	MKL_LONG status;
	//...put input data into x_in[0],...,x_in[31]; y_in[0],...,y_in[31]
	for (int i = 0; i < 32; i++)
		x_in = cos(2 * 3.1415926535897932384626433832795*i * 4 / 32);
	status = DftiCreateDescriptor(&my_desc1_handle, DFTI_SINGLE,
		DFTI_COMPLEX, 1, 32);
	status = DftiSetValue(my_desc1_handle, DFTI_PLACEMENT, DFTI_NOT_INPLACE);
	status = DftiCommitDescriptor(my_desc1_handle);
	status = DftiComputeForward(my_desc1_handle, x_in, x_out);
	status = DftiFreeDescriptor(&my_desc1_handle);
	/* result is x_out[0], ..., x_out[31]*/
	status = DftiCreateDescriptor(&my_desc2_handle, DFTI_SINGLE,
		DFTI_REAL, 1, 32);
	Status = DftiSetValue(My_Desc2_Handle, DFTI_PLACEMENT, DFTI_NOT_INPLACE);
	status = DftiCommitDescriptor(my_desc2_handle);
	status = DftiComputeForward(my_desc2_handle, y_in, y_out);
	status = DftiFreeDescriptor(&my_desc2_handle);
	/* result is given by y_out in CCS format*/
And I have problems with the float _Complex type.
I have set the '/Qstd=c99' option in my project but visual studio returns an error about this option. It says "the '/Qstd=c99' option is not valid for C++ compilations"
My program is not a c++ program
Any idea to solve this problem
Remi
Viet_H_Intel
You have included iostream, which is C++ header.
Gouyon_R_
I have made a new project with no iostream and no pch.h. and rename my main fin in .c instead of .cpp
It has no effect the error is the same.
The problem is that it does not fin the definition of float _Complex
jimdempseyatthecove
I do not see that you are including
#include <complex.h>
see: https://www.gnu.org/software/libc/manual/html_node/Complex-Numbers.html
Jim Dempsey
Gouyon_R_
I have tried but it's not working. I use the complex.h witch is in the ..\compilers_and_libraries_2019\compilers\include\ directory
I haver also tried without the '/Qstd=c99'  option and it does not work
Viet_H_Intel
I wonder if your test program works with cl?
Gouyon_R_
I have the solution from intel support
#include <stdlib.h>
#include <stdio.h>
#include "mkl.h"
#include <math.h>
int main()
	MKL_Complex8 x_in[32];
	MKL_Complex8 x_out[32];
	//float x_in[32];
	//float x_out[32];
	float y_in[32];
	float y_out[34];
	DFTI_DESCRIPTOR_HANDLE my_desc1_handle = 0;
	DFTI_DESCRIPTOR_HANDLE my_desc2_handle = 0;
	MKL_LONG status;
		x_in.real = cos(2 * 3.1415926535897932384626433832795*i * 4 / 32);
		x_in.imag = cos(2 * 3.1415926535897932384626433832795*i * 4 / 32);
	status = DftiCreateDescriptor(&my_desc1_handle, DFTI_SINGLE, DFTI_COMPLEX, 1, 32);
	status = DftiCreateDescriptor(&my_desc2_handle, DFTI_SINGLE, DFTI_REAL, 1, 32);
	status = DftiSetValue(my_desc2_handle, DFTI_PLACEMENT, DFTI_NOT_INPLACE);
	return status;
Fowler__Austin
Where can I find mkl.h?
