Intel® C++ Compiler
7956 Discussions
Schedule IA-64 code with ecc toolchain?
Intel_C_Intel
Is it possible to use the IA-64 ecc tools to do any form of scheduling of assembler code.
I can't find any hints in the documentation (but I know there are undocumented features :-)
Does any one have any suggestion for tools to schedule IA64 assembler?
/Tommy
david_a_levinthal
are you trying to create an inline asm?
only mechanism for that is to create an asm function and then get the compiler to inline it with IP/IPO & maybe pgo
or better use the inline, __inline or __forceinline declarations to force inlining of the asm sequence
is that what you mean?
alternatively..
build an asm file (with the -use_asm flag to get an asm listing that can be recompiled..)
edit the assembler
create an obj with
ias -W DVLoc_off myfile.asm
and link your program again
Intel_C_Intel
No, I am aware of the fact that ecc doesn't support inline assembler for IA64 so I'm not trying to do inline.
I have a program generator that generates assembler (and no, rewriting it to generate high level languages is not an option).
Making the generator generate scheduled assembler is a too big effort so I was hopping for something that could take an assembler file and help me with getting a scheduled object file.
I haven't tried IPO and inlining yet, but if that works there MUST be some functionality somewere, that takes an assembler (or binary) file and parses it into a context that does scheduling. If that is the case it should be possible to get my assembler in there without wrapping a high level context around it :-)
The last suggestion doesn't help at all, since ias only does bundling and/or dependecy violation ananlysis, but NO scheduling
(and turning the dependecy violation check of does not improve the situation the slightest, quite the opposite actually).
/Tommy
