Intel® C++ Compiler
7956 Discussions
asm blocks not enabled, use -fasm-blocks
harshada28
I am trying to run my Makefile with icc (11.1) as compiler.
During make I got following error:
"asm blocks not enabled, use -fasm-blocks "
Found some post related to this and accordingly I tried to set CFLAGS=-fasm-blocks during make.
Then some other errors are prompted.
What could be the problem?
thanks,
Harshada.
aazue
Hi
Maybe...
Use (./configure --help) to show all options you have default autoconf, if exist ...??
harshada28
How would "configure help" help actually? Nwys I tried even configure --help also.
I tried to set CFLAGS=-fasm-blocks. But no luck.
aazue
Hi
You can have some times specific flags that it must be obligatory used. declare flags stored ENV not working ...
Do not think that ./configure --help show exactly same all packages;
different with each package , (is not an help how to use 'configure' generally)
make ./configure --help 2 different packages source you understand probably
you build Is working well with using Gnu compiler ?
Regards ...
Dale_S_Intel
I believe -fasm-blocks allows the compiler to recognize "MS style" asm blocks, as opposed to the standard gcc style asm statements. Among the possibilities are that there are some problems with the asm code, or there may be some confusion if there is some mixing of asm styles in the same file, but I'm not really sure. Can you post some more info, like some of the actual errors or better yet a reproducible test case?
Thanks!
Dale
harshada28
I am pasting the acutal error here:
noisereduction.c(229): error: asm blocks not enabled, use -fasm-blocks
__asm {
noisereduction.c(248): error #12: parsing restarts here after previous syntax error
And the code is:
__asm {
mov eax, 0
cpuid
mov long ptr [vender+0], ebx
mov long ptr [vender+4], edx
mov long ptr [vender+8], ecx
__asm {
mov eax, 01h
cpuid
mov cpeinfo, edx
mov cpsse3, ecx
Om_S_Intel
The -fasm-blocks option works for me.
$ cat x.c
void foo()
__asm {
mov eax, 0
cpuid
__asm {
mov eax, 01h
cpuid
$ icc -c -fasm-blocks x.c
$ icc -v
Version 12.0.1
Om_S_Intel
This also wors in icc 11.1. Could you please tell me your compiler version?
