my program has 7 modules..the warning comes for 2 files oct.c and
dataoct.c which have their corresponding header files oct.h and
dataoct.h..
the above warning comes only when i run the program in an icc compiler..gcc compiler runs it fine..also making a struct octtree *tree global the way we had done it in the gcc compiler is not being possible..
could anyone tell me if there is any difference in the way we globalise a structure in gcc and icc compilers???
"no action performed..." normally comes about when specifying -c option and including .o files. gcc simply doesn't issue a warning, but performs the same action/inaction as icc. So you should at least show the command which produces this.
For your second issue, I don't see how we can guess what you are doing. Are you using a gcc extension? "globalize" seems more like economic than software jargon. A few gcc extensions have lost viability due to conflict with C99 standard. You could check this by testing stricter options in gcc.
