from here , i can see that "-debug inline-debug-info" will tell us the debug information, But i see nothing ,no terminal output ,no files like temp.txt
My commands:
icpx -debug inline-debug-info -g -O3 demo-test.cpp
icpx -debug all -g -O3 demo-test.cpp
$:demo-test$ icpx --version
Intel(R) oneAPI DPC++/C++ Compiler 2023.1.0 (2023.1.0.20230320)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2023.1.0/linux/bin-llvm
Configuration file: /opt/intel/oneapi/compiler/2023.1.0/linux/bin-llvm/../bin/icpx.cfg
please tell me what should i do to get the debug information out.
Great Thanks!
To capture debug information using the Intel oneAPI DPC++/C++ Compiler, you can follow these steps:
1. **Check Compiler Version:**
Ensure that you are using a version of the compiler that supports the debug options. In your case, you are using Intel oneAPI DPC++/C++ Compiler version 2023.1.0, which is up to date.
```bash
icpx --version
2. **Debug Information Flags:**
Use the appropriate debug information flags when compiling your code. In your case, you've used the `-debug inline-debug-info` flag, which should generate inline debug information.
```bash
3. **Output Location:**
By default, debug information is often embedded in the executable or object file. However, you may not see separate files like `temp.txt` or terminal output when using the inline debug info option.
4. **Verify Debug Information:**
To verify if debug information is present, you can use tools like `readelf` or `objdump`. For example:
```bash
readelf -wi demo-test
This command will display debugging information in the ELF file.
```bash
objdump -S demo-test
This command will display source code intermixed with the assembly.
If you are still facing issues, consider using `-debug all` for more comprehensive debug information:
```bash
Remember that the availability and format of debug information can depend on the optimization level and other factors. If you encounter difficulties, consulting the Intel oneAPI documentation or community forums for specific guidance may be beneficial.
Certainly! Here's the modified line with the link:
Explore innovative web design and development solutions tailored to your needs at https://seatechinnovations.net/. Elevate your online presence with our expert team at the forefront of digital creativity and technology.
The debug flag is used to enable or disable the generation of debugging information.
When you compile a program with debug flag enabled, it includes debugging information in the executable. You can debug the applications using Intel Distribution for GDB(gdb-oneapi).
Please refer to the below links for more information.
Please let us know if you face any issues.
Thanks and Regards,
Pendyala Sesha Srinivas
Thanks @SeshaP_Intel
I think i made a mistake with debug information included in the executable and debug information of the compiler.
what i want to see is the debug information of the compiler, what oneapi has done to my function:
for example:
- Does this function been inlined
- Does this loop been vectorized
Finally ,i find that i can do this by “qopt-report-file”:
icpx -O3 -flto -ipo -qopt-report-file=stdout demo-test.cpp
if you have more detailed information that i can see by any other compiler option, please tell me
HAPPY SANTAAAAA!
The debug information is to be used by debug tools or vtune. They are not readable by human being.
```bash
icpx --version
```bash
```bash
```bash
```bash
Great thanks to all of you!
i have figured it out not only the debug info of the executable but the debug info of the compiler. So this question will be closed.
Again , Thanks!
To access debug information in oneAPI, compile your code with the flag to include debugging symbols. Use the oneAPI command-line debugger, , by running your executable with as follows: . You can set breakpoints, inspect variables, and navigate your code for debugging purposes. Depending on your toolkit version, there may also be a graphical debugger interface. Check the oneAPI documentation for specific instructions tailored to your toolkit and version.
For debugging with oneAPI, you can explore the generated log files and console output. The oneAPI tools, such as Intel Advisor or Intel VTune Profiler, often produce detailed logs during execution. Additionally, check the console or terminal where you run your oneAPI application for real-time debug information. Adjusting the verbosity level in tool settings or utilizing specific debugging flags can enhance the amount of information provided. Consult the documentation of the specific oneAPI tool you're using for detailed instructions on accessing and interpreting debug information.
