How can I run my job on a GPU!
Please use the below command to submit a job in GPU node:
qsub -l nodes=1:gpu:ppn=2 -d . job.sh
Note: -l nodes=1:gpu:ppn=2 (lower case L) is used to assign one full GPU node to the job.
Note: The -d . is used to configure the current folder as the working directory for the task.
Note: job.sh is the script that gets executed on the compute node.
Please refer the following documentation for detailed information:
https://devcloud.intel.com/oneapi/documentation/job-submission/
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Thank you.
We have not heard back from you. Could you please give us an update?
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
