Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
451 Discussions
Getting error when importing dpnp.dparray with dpnp 0.10.1 or 0.10.2 on Windows 10
DManowitz
When I try to import dpnp.dparray with dpnp v0.10.1 (using either Python 3.7 or 3.8) or v0.10.2 (using Python 3.8, since no version available for Python 3.7) on Windows 10, I get the following error:
File "dpnp\dparray.pyx", line 40, in init dpnp.dparray
TypeError: Cannot overwrite C type array
I did not get this error when importing dpnp.dparray in dpnp v0.10.0 (using either Python 3.7 or 3.8)
Can someone investigate this?
Rahila_T_Intel
Thanks for posting in Intel communities.
We are unable to reproduce the issue from our end.
is it the below command you used to install dpdnp as mentioned in https://intelpython.github.io/dpnp/install.html#installing-dpnp-from-source
conda install -c intel dpnp
Could you please provide the command you used to install dpnp version 0.10.1 and 0.10.2.
DManowitz
The simplest way I was able to reproduce this error was to first set my .condarc to the following:
channels:
- intel
- defaults
I then created new conda environments (one with Python 3.7 and one with Python 3.8), which installed the Intel Python versions, and executed
conda install intelpython3_full
This installed dpnp v0.10.1 as part of its dependencies.
I was also able to reproduce the problem after creating Python 3.7 and 3.8 environments using the following .condarc file:
channel_priority: disabled
channels:
  - pytorch
  - conda-forge
  - intel
  - defaults
This interestingly installed the Intel Python version for Python 3.7, but the conda-forge Python version for 3.8.  In either case, I then installed several of the Intel python packages into these environments and was also able to reproduce the problem using dpnp v0.10.1.
At this point, I noticed that dpnp v0.10.2 was available for Python 3.8, so I wondered if that would fix the problem.  I was able to install it into my conda-forge environment, but I was not able to install it into my initial Python 3.8 environment, as the intelpython3_full package constrained dpnp to be v0.10.1.
I was then able to reproduce the problem again in my conda-forge environment with dpnp v.0.10.2.
Rahila_T_Intel
We are able to reproduce the issue from our end.
We are checking on this internally and will share you the updates.
Rahila_T_Intel
Could you please provide the details regarding the requirement of dpnp.dparray in your code. Because dpnp.dparray is depreciated and it should not be used. You can use dpnp methods directly.
Also please try to remove import dpnp.dparray and confirm whether it is still running fine. If not, please provide the dparray usage, We can provide the alternative dpnp method.
DManowitz
I did not realize that dpnp.dparray is deprecated.  I will stop using it then.
DManowitz
Although, admittedly, you should issue a warning about the package being deprecated, not an error.
Rahila_T_Intel
Thank you for your feedback. We have provided your feedback to the relevant team.
Please let me know if we can go ahead and close this case?
DManowitz
Yes, you can go ahead and close this case.
Rahila_T_Intel
Thanks for sharing the confirmation.
Glad to know that your query is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
