Cannot install SDK
I have tried to install the SDK (ubuntu) but i get to an error i cannot resolveSetting up libprotobuf-dev:amd64 (2.6.1-1.3) …
Setting up libsnappy-dev:amd64 (1.1.3-2) …
Setting up protobuf-compiler (2.6.1-1.3) …
Setting up python3-scipy (0.17.0-1) …
Processing triggers for libc-bin (2.23-0ubuntu9) …
Reading package lists…
Building dependency tree…
Reading state information…
libboost-all-dev is already the newest version (1.58.0.1ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
Installing python dependencies…
./install-ncsdk.sh: line 282: -H: command not found
./install-ncsdk.sh: line 283: -H: command not found
Checking whether tensorflow is installed…
looking for tensorflow CPU version…
./install-ncsdk.sh: line 248: -H: command not found
looking for tensorflow GPU version…
Couldn't find a supported tensorflow version, installing tensorflow v1.3.0
./install-ncsdk.sh: line 303: -H: command not found
Installation failed. Error on line 303
I am trying to run it on a joule sdk extended with 128GB SD
Any help is appreciated
Cheers
For reference I am running UBUNTU 16.04 so it should be compatible.
Same here with a fresh install of 16.04
Trying to use the quickstart (https://developer.movidius.com/start). Sadly, "make install" fails /very/ quickly with
cp: cannot create regular file './ncsdk.conf': Permission denied
Movidius Neural Compute Toolkit Setup.
Checking OS and version…
Installing on Ubuntu 16.04
mkdir: cannot create directory ‘/opt/movidius/NCSDK/setup-logs’: Permission denied
Installation failed. Error on line 136
Trying "sudo make install" gets /much/ further along, before the /next/ error is found:
Once I hacked your install.sh to /not/ delete "install-ncsdk.sh", one problem quickly appears around line 276:
if [ $SYSTEM_INSTALL == "yes" ]; then
PIP_PREFIX="$SUDO_PREFIX -H"
fi
This /very/ error is described in another post https://ncsforum.movidius.com/discussion/308/installation-error-on-sdk-1-09-00-fails-to-find-install-tensorflow. Oddly, the claim is made in that post that the installation should be run as a normal user, which doesn't actually work _at_ _all_.
Please advise.
normal user install does not work also for me.. I have modified the script of installation at the part where it does the python dependencies and it works.
I believe is in the link given above.
After that it works
Fixing the permission errors shown above for "./ncsdk.conf" and "/opt/movidius/NCSDK/setup-logs" as well as fixing the if statement in install-ncsdk.sh does allow the installation to proceed and complete without sudo.
HOWEVER, there are yet multiple other permission errors related to tee(1) in install-ncsdk.sh.
Summary:
@dnl Can you please specify what HW/SW are you using? Is it a regular PC or some board like Odroid or Joule?
@dnl @fpex Also will be good if you provide any logs during your installation process so we'll be able to reproduce on our side and consider better where issue comes from.
I managed to install the SDK with the changes mentioned in the post above. It is just an issue of installing with sudo (without it also failed)
Ran into this same problem. I could get install.sh to work using the following approach. It seems the only reason to use sudo at all in the script is to get write access to /opt. The solution is to create /opt/movidius and make it owned by the user. Then remove all the "sudo" in the install.sh script and it seems to run as ordinary user just fine.
