29331 Discussions
Can I pass data to a module without copying?
Zhanghong_T_
Hi all,
Recently a problem bored me. I defined a module contains a set of subroutines. Some data will pass to one subroutine of the module. I wish the data can be visited by many subroutine of the module. One way is to define a set of same structure variants and copy the data to these variants. But when the input data size is very large, this method will waste memory. Can I directly use the input variants and set it public (or they are global variants)in the module (I don't like to pass these variants during the subroutines of the module).
Zhanghong Tang
Jugoslav_Dujic
Valued Contributor II
Yes you can.
Note, however, that passing data as argument do NOT involve any copy of the memory (with some exceptions).
A typical designfor such issuesis that you provide the data declarations within the module but keep them PRIVATE, and then define one or more routines which are dedicated to Read/Write the data. In this way, the data are accessible only by the module itself, and only these mentioned Set/Get routinesare used to communicate with the "outer world". Your mileage may vary, of course.
Jugoslav
Zhanghong_T_
Thank you very much!
How should I modify the following program?
module test
contains
subroutine readdata(n, x, y)
implicit none
integer n
real*8 x(n), y(n)
call outputdata(n, x, y)
end subroutine
subroutine outputdata(n, x, y)
implicit none
integer n
real*8 x(n), y(n)
integer i
do i=1, n
write(*, *) x(i), y(i)
enddo
end subroutine
end module
program
use test
implicit none
integer:: n=100
real*8:: x(n), y(n)
call readdata(n, x, y)
end
Jugoslav_Dujic
As is, that does not make much sense, because it does notever define x and y.But for example:
module test
private
integer:: n
real(8), allocatable:: x(:), y(:)
public readdata
public outputdata
contains
subroutine readdata(sfilename)
implicit none
character(*):: sfilename
integer:: i
open(11,file=sfilename,action='read')
read(11, "(i4)") n
allocate(x(n), y(n))
do i=1,n
read(11,"(2f10.0)") x(i), y(i)
end do
close(11)
end subroutine readdata
subroutine outputdata()
implicit none
integer i
do i=1, n
enddo
end subroutine outputdata
subroutine freedata()
deallocate(x, y)
end subroutine freedata
end module test
program
use test
implicit none
character(100):: sfilename
call getarg(1, sfilename)
call readdata(sfilename)
call outputdata()
call freedata()
end program
Jugoslav
Message Edited by JugoslavDujic on 06-28-2004 02:01 PM
Zhanghong_T_
Thank you again!
I know the data can be passed by file, but when the size of arrays is up to several million or more, it will waste much time to write and read data. Is there any way to make it possible to define an entrance for the module, then data passed from the entrance and shared by the module?
Sincerely,
Zhanghong Tang
Jugoslav_Dujic
Well, yes. I was just writing an illustration.
Jugoslav
Zhanghong_T_
I am waiting for your illustration...
Thank you!
Jugoslav_Dujic
Well, you can declare X and Y public and access them from outside the module as any other variables...
...or you can make them POINTERs, and use assignment-operator => to point them to "real" data which come from elsewhere...
...but where do your "zillions" of data come from? Ultimately, they probably come from a file and get stored in a file. Or they're perhaps intermediate results from another calculation; in any case, it's a good idea to have just one module which deals with input/output of data.
Jugoslav
