29392 Discussions
Help: how to specify 'stack reserve size' in command line?
Zhanghong_T_
Hi all,
I need to specify the stack reserve size in command line when compiling. I tried to specify by typing such as
/stack:50000000
but failed. Can anyone give me some suggestion?
Zhanghong Tang
Use /link/stack:50000000
/stack is a linker switch so you have to precede it by /link to tell ifort to pass it (and everything after that on the command line) to the linker.
Zhanghong_T_
Hi Steve,
Thank you very much. I got it.
Zhanghong Tang
