29039 Discussions
ICE of ifx 2024.1.0 for undefined procedure names in constructors
V-T
Consider the following minimal example:
program p
    interface
        function i()
        end
    end interface
    type t
        procedure(i),pointer,nopass::f
    end type
    type(t)::o
    o=t(f)  ! error #8191
end
The compilation of this code ends with an error `error #5633: **Internal compiler error: segmentation violation signal raised**`. This happens because an undefined procedure name `f` is used in the constructor.
If a procedure `f` is defined, but with wrong argument types like in the following code:
program p
    interface
        function i(x)result(c)
            real::x(:),c(SIZE(x))
        end function
    end interface
    type t
    end type
    type(t)::o
    o=t(f)
contains
    function f(x)result(c)
        integer::x(:),c(SIZE(x))  ! wrong type
        c=x
    end
end
 another ICE (`error #5623`) occurs.
Labels (2)
Devorah_H_Intel
This issue was fixed in ifx 2025.1
Get Intel® oneAPI HPC Toolkit
Barbara_P_Intel
I filed a bug report on these two ICEs. Thanks for the small reproducers.
Glad you have workarounds!
We'll let you know when the fix is available.
Devorah_H_Intel
