29487 Discussions
Internal compiler error calling REDUCE(3f)
ur
New Contributor II
Does this produce an error with the latest version of ifort(1)?
     program demo_reduce
      use, intrinsic :: iso_fortran_env, only : compiler_version, compiler_options
      implicit none
      real,allocatable :: arr(:)
        print '(4a)', &
           'This file was compiled by ', &
           compiler_version(),           &
           ' using the options ',        &
           compiler_options()
         arr=[1.0, -1.0, 2.0, -2.0, 3.0 -3.0 ]
         write(*,*)reduce(arr, my_mult)
         write(*,*)reduce(arr, my_mult, mask=arr>0.0)
      contains
         pure function my_mult(a,b) result(c)
         real,intent(in) :: a, b
         real            :: c
            c=a*b
         end function my_mult
      end program demo_reduce
! bug.f90(6): catastrophic error: **Internal compiler error: internal abort**
!             Please report this error along with the circumstances in
!             which it occurred in a Software Problem Report.  Note:
!             File and line given may not be explicit cause of this error.
! This file was compiled by Intel(R) Fortran Intel(R) 64 Compiler
! Classic for applications running on Intel(R) 64, Version 2021.3.0 Build
! 20210609_000000 using the options
Devorah_H_Intel
I tested it with 2021.6 ifort and there is an ice.
However the upcoming 2021.7 ifort (part of oneAPI HPC toolkit 2022.3 to be released soon) doesn't ICE.
Devorah_H_Intel
ur
New Contributor II
Thanks. That eliminates trying to post a bug report; testing it out more completely can wait till I get upgraded.
